System Administration Guide: IP Services
IPv6 Network Interface Configuration File
IPv6 uses the file /etc/hostname6.interface at start up to automatically define network interfaces in the same way IPv4 uses /etc/hostname.interface. A minimum of one /etc/hostname.* or /etc/hostname6.* file should exist on the local machine. The Solaris installation program creates these files for you. In the file name, replace interface with the device name of the primary network interface.
The file name has the following syntax:
hostname.interface
hostname6.interface
Interface has the following syntax:
dev[.Module[.Module ...]]PPA
Dev
A network interface device. The device can be a physical network interface, such as le, qe, and so on, or a logical interface, such as a tunnel. See Solaris Tunneling Interfaces for IPv6 for more details.
Module
The list of one or more streams modules to be pushed onto the device when the device is plumbed.
PPA
The physical point of attachment.
The syntax [.[.]] is also accepted.
The following list shows examples of valid file names:
hostname6.le0
hostname6.ip.tun0
hostname.ip.tun0
IPv6 Interface Configuration File Entry
The autoconfiguration of interfaces in IPv6 enables a node to compute its own link-local address that is based on its link-layer address. Consequently, the interface configuration file for IPv6 might not have an entry. In this instance, the startup scripts configure an interface. The node then “learns” of other addresses and prefixes through the neighbor discovery daemon, in.ndpd. If you require static addresses for an interface, use the ifconfig utility. Consequently, the address or host name is stored in /etc/hostname6.interface (or /etc/hostname.interface. The content is passed to ifconfig when the interface is configured.
In this instance, the file contains only one entry. The entry is the host name or IP address that is associated with the network interface. For example, suppose smc0 is the primary network interface for a machine that is called ahaggar. The /etc/hostname6.* file for the interface would have the name /etc/hostname6.smc0. The file would contain the entry ahaggar.
The networking start up script examines the number of interfaces and the existence of the /etc/inet/ndpd.conf file to start routing daemons and packet forwarding. See How to Configure a Solaris IPv6 Router.
IPv6 Extensions to the ifconfig Utility
The ifconfig utility now enables IPv6 interfaces and the tunneling module to be plumbed. The ifconfig(1M) utility uses an extended set of ioctls to configure both IPv4 and IPv6 network interfaces. The following table shows the set of options that are added to this utility. See How to Display Interface Address Assignments for a description of useful diagnostic procedures that use this utility.
Table 16–1 New ifconfig Utility Options
Option
Description
index
Set the interface index.
tsrc/tdst
Set tunnel source or destination.
addif
Create the next available logical interface.
removeif
Delete a logical interface with a specific IP address.
destination
Set the point-to-point destination address for an interface.
set
Set an address, netmask, or both for an interface.
subnet
Set the subnet address of an interface.
xmit/-xmit
Enable or disable packet transmission on an interface.
Enabling IPv6 Nodes provides IPv6 configuration procedures.
Examples—New ifconfig Utility Options
The following usage of the ifconfig command creates the hme0:3 logical interface to the 1234::5678/64 IPv6 address. This command enables the interface with the up option. The command also reports status. The command disables the interface. Finally, the command deletes the interface.
Example 16–1 Examples—Using addif and removeif
# ifconfig hme0 inet6 addif 1234::5678/64 up
Created new logical interface hme0:3
# ifconfig hme0:3 inet6
hme0:3: flags=2000841<UP,RUNNING,MULTICAST,IPv6> mtu 1500 index 2
		inet6 1234::5678/64
# ifconfig hme0:3 inet6 down
# ifconfig hme0 inet6 removeif 1234::5678
The following usage of the ifconfig command opens the device that is associated with the physical interface name. The command configures the streams that are needed for TCP/IP to use the device. The command reports the status of the device. The command configures the source and the destination address for the tunnel. Finally, the command reports the new status of the device after the configuration.
Example 16–2 Examples—Using tsrc/tdst and index
# ifconfig ip.tun0 inet6 plumb index 13
ip.tun0: flags=2200850<POINTOPOINT,RUNNING,MULTICAST,NONUD,IPv6> mtu
1480 index 13
		inet tunnel src 0.0.0.0
		inet6 fe80::/10 --> ::
# ifconfig ip.tun0 inet6 tsrc 120.46.86.158 tdst 120.46.86.122
1480 index 13
		inet tunnel src 120.46.86.158  tunnel dst 120.46.86.122
		inet6 fe80::8192:569e/10 --> fe80::8192:567a
