System Administration Guide: IP Services
Enabling IPv6 Nodes
This section provides procedures that you might need to configure IPv6 nodes on your network.
Note –
The term node in this context refers either to a Solaris server or client workstation.
Enabling IPv6 Nodes Task Map
Table 15–1 Enabling IPv6 Nodes Task Map
Task
Description
For Instructions, Go to ...
Enable IPv6 on a node
Involves touching hostname6.interface file, displaying addresses, and entering the addresses in the /etc/inet/ipnodes file. (See note.)
How to Enable IPv6 on a Node
Configure a Solaris IPv6 router
Involves adding entries to the indp.conf file.
How to Configure a Solaris IPv6 Router
Add IPv6 addresses to NIS and NIS+
Involves adding entries to the /etc/ipnodes file.
How to Add IPv6 Addresses to NIS and NIS+
Add IPv6 addresses to DNS
Involves adding AAAA records to the DNS zone and reverse zone file.
How to Add IPv6 Addresses to DNS
Note –
You can enable IPv6 on a system when you install the Solaris software. If you answered yes to enable IPv6 during the installation process, you can omit the following procedures to enable IPv6.
  1. Become superuser on the system where you want to enable IPv6.
  2. On a command line, type the following for each interface.
    # touch /etc/hostname6.interface
    Interface
    Interface name, such as le0, le1.
  3. Reboot.
    Note –
    The reboot process sends out router discovery packets. The router responds with a prefix. The response enables the node to configure the interfaces with an IP address. Rebooting also restarts key network daemons in IPv6 mode.
  4. On a command line, display the IPv6 addresses.
    # ifconfig -a
  5. Add the IPv6 address to the appropriate name service as follows:
  1. Become superuser on the system that acts as a router.
  2. Edit the file /etc/inet/ndpd.conf with subnet prefixes by adding one or more of the following entries.
    See the in.ndpd(1M) man page for a list of variables and allowable values. For more information about the ndpd.conf file, see the ndpd.conf(4) man page.
    1. Add entries that specify router behavior for all interfaces.
      ifdefault variable value
    2. Add entries that specify the default behavior of prefix advertisement.
      prefixdefault variable value
    3. Add sets per interface parameter entries.
      if interface variable value
    4. Add advertisements for each entry for interface prefix information.
      prefix prefix/length interface variable value
  3. Reboot the system.
Note –
Neighbor discovery (in.ndpd) relays the subnet address prefixes of the hosts to the hosts. Also, the next generation RIP routing protocol (in.ripngd) runs automatically.
Example—ndpd.conf Router Configuration File
# Send router advertisements out all NICs
ifdefault AdvSendAdvertisements on
# Advertise a global prefix and a
# site local prefix on three interfaces.
# 0x9255 = 146.85
prefix 2:0:0:9255::0/64	 	hme0
prefix fec0:0:0:9255::0/64 	hme0
# 0x9256 = 146.86
prefix 2:0:0:9256::0/64 	hme1
prefix fec0:0:0:9256::0/64	hme1
# 0x9259 = 146.89
prefix 2:0:0:9259::0/64		hme2
prefix fec0:0:0:9259::0/64	hme2
A new table has been added for NIS+ named ipnodes.org_dir. The table contains both IPv4 and IPv6 addresses for a host. The existing hosts.org_dir table, which contains only IPv4 addresses for a host, remains the same to facilitate existing applications. Both the hosts.org_dir and ipnodes.org_dir tables must be consistent with the IPv4 addresses. See IPv6 Extensions to Solaris Name Services for an overview.
Administration of the new ipnodes.org_dir table is similar to administering the hosts.org_dir. The same tools and utilities that are used in administering the previous NIS+ tables are valid for ipnodes.org_dir. See System Administration Guide: Naming and Directory Services for details on how to manipulate the NIS+ table.
The following procedure merges the entries from /etc/inet/ipnodes into the ipnodes.org_dir table (in verbose mode). The NIS+ table was probably created by nistbladm(1), nissetup(1M), or nisserver(1M).
    On a command line, type the following command:
    % nisaddent -mv -f /etc/inet/ipnodes ipnodes
Use the following procedure to display the ipnodes.org_dir table.
    % nisaddent -d ipnodes
Two new maps have been added for NIS: ipnodes.byname and ipnodes.byaddr. These maps contain both IPv4 and IPv6 host name and address associations. The hosts.byname and hosts.byaddr maps, which contain only IPv4 host name and address associations, remain the same to facilitate existing applications. Administration of the new maps is similar to the maintenance of the hosts.byname and hosts.byaddr older maps. Again, it is important that when you update the hosts maps with IPv4 addresses that the new ipnode maps are also updated with the same information.
Note –
Tools that are aware of IPv6 use the new NIS maps and the new NIS+ tables.
  1. Become superuser on system that has DNS.
  2. Edit the appropriate DNS zone file by adding AAAA records for the IPv6–enabled host, using the following format.
    host-name  IN   AAAA 	host-address
  3. Edit the DNS reverse zone file and add PTR records, using the following format.
    host-address IN   PTR   host-name
See RFC 1886 for more information about AAAA and PTR records.
Example—DNS Zone File
vallejo		IN		AAAA   2::9256:a00:20ff:fe12
IN		AAAA   fec0::9256:a00:20ff:fe12:528
Example—DNS Reverse Zone File
$ORIGIN	ip6.int.
8.2.5.0.2.1.e.f.f.f.9.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.2.0.0.0 \
	IN		PTR		vallejo.Eng.apex.COM.
8.2.5.0.2.1.e.f.f.f.9.2.0.0.a.0.6.5.2.9.0.0.0.0.0.0.0.0.0.c.e.f \
