System Administration Guide: IP Services
How to Enable IPv6 on a Node
  1. Become superuser on the system where you want to enable IPv6.
  2. On a command line, type the following for each interface.
    # touch /etc/hostname6.interface
    Interface name, such as le0, le1.
  3. Reboot.
    Note –
    The reboot process sends out router discovery packets. The router responds with a prefix. The response enables the node to configure the interfaces with an IP address. Rebooting also restarts key network daemons in IPv6 mode.
  4. On a command line, display the IPv6 addresses.
    # ifconfig -a
  5. Add the IPv6 address to the appropriate name service as follows:
