In this procedure, you use the traceroute command to trace all routes.
On the command line, type the following command.
% traceroute -a <hostname> |
For more information on the traceroute command, see the traceroute(1M) man page.
% traceroute -a ipng11 traceroute: Warning: Multiple interfaces found; using 2::56:a0:a8 @ le0:2 traceroute to ipng11 (2::102:a00:fe79:19b0),30 hops max, 60 byte packets 1 ipng-rout86 (2::56:a00:fe1f:59a1) 35.534 ms 56.998 ms * 2 2::255:0:c0a8:717 32.659 ms 39.444 ms * 3 ipng61.Eng.apex.COM (2::103:a00:fe9a:ce7b) 401.518 ms 7.143 ms * 4 ipng12-00 (2::100:a00:fe7c:cf35) 113.034 ms 7.949 ms * 5 ipng11 (2::102:a00:fe79:19b0) 66.111 ms * 36.965 ms traceroute: Warning: Multiple interfaces found; using fec0::56:a8 @ le0:1 traceroute to ipng11 (fec0::10:b0), 30 hops max, 60 byte packets 1 ipng-rout86 (fec0::56:a00:fe1f:59a1) 96.342 ms 78.282 ms 88.327 ms 2 ipng8-tun1 (fec0::25:0:0:c0a8:717) 268.614 ms 508.416 ms 438.774 ms 3 ipng61.Eng.apex.COM (fec0::103:a00:fe9a:ce7b) 6.356 ms * 713.166 ms 4 ipng12-00 (fec0::100:a00:fe7c:cf35) 7.409 ms * 122.094 ms 5 ipng11 (fec0::102:a00:fe79:19b0) 10.620 ms * * traceroute to ipng11.eng.apex.com (190.68.10.75),30 hops max,40 byte packets 1 rmpj17c-086.Eng.apex.COM (120.46.86.1) 4.360 ms 3.452 ms 3.479 ms 2 flrmpj17u.Eng.apex.COM (120.46.17.131) 4.062 ms 3.848 ms 3.505 ms 3 ipng8.Eng.apex.COM (120.68.7.23) 4.773 ms * 4.294 ms 4 ipng61.Eng.apex.COM (120.68.10.104) 5.128 ms 5.362 ms * 5 ipng12-20.Eng.apex.COM (120.68.10.62) 7.298 ms 5.444 ms * 6 ipng11.Eng.apex.COM (120.68.10.75) 8.053 ms 6.394 ms * |
