System Administration Guide: IP Services
Monitoring IPv6 Task Map
Table 15–2 Monitoring IPv6 Task Map
Task
Description
For Instructions, Go to ...
Display interface address assignments
Displays all, or just IPv4, or just IPv6 address assignments by using ifconfig command.
How to Display Interface Address Assignments
Display network status
Displays all sockets and routing table entries. Displays inet address family for IPv4. Displays inet6 address family for IPv6. Displays statistics for IPv6 or ICMPv6 counters of interfaces by using the netstat command.
How to Display Network Status
Control the display output of IPv6 related commands
Controls the output of the ping, netstat, ifconfig, and traceroute commands. Creates a file that is named inet_type. Sets the DEFAULT_IP variable in this file.
How to Control the Display Output of IPv6 Related Commands
Monitor only IPv6 network traffic
Displays all IPv6 packets by using the snoop command.
How to Monitor Only IPv6 Network Traffic
Probe all multihomed host addresses
Checks all addresses by using the ping command.
How to Probe All Multihomed Host Addresses
Trace all routes
Uses the traceroute command.
How to Trace All Routes
