This option enables IPsec ESP for a tunnel with the encryption algorithm specified. The option has the following format:
encr_algs encryption_algorithm |
For the algorithm, you can specify either a number or an algorithm name. You must specify all IPsec tunnel properties on the same command line. To disable tunnel security, specify the following option:
encr_alg none |
If you specify an ESP authentication algorithm, but not an encryption algorithm, the ESP encryption value defaults to the parameter null.
See the ipsecesp(7P) man page or Table 19–2 for a list of available encryption algorithms and for pointers to the algorithm man pages.
