System Administration Guide: Resource Management and Network Services
Mail Alias Files
You can use any of the following files, maps, or tables to maintain aliases.
Your method of maintaining aliases depends on who uses the alias and who needs to be able to change the alias. Each type of alias has unique format requirements.
If you are looking for task information, refer to Administering Mail Alias Files (Task Map) in Chapter 25, Mail Services (Tasks).
.mailrc Aliases
Aliases that are listed in a .mailrc file are accessible only by the user who owns the file. This restriction enables users to establish an alias file they control and that is usable only by its owner. Aliases in a .mailrc file adhere to the following format.
alias aliasname value value value ...
aliasname is the name that the user uses when sending mail, and value is a valid email address.
If a user establishes a personal alias for scott that does not match the email address for scott in the name service, mail is routed to the wrong person when people try to reply to mail that is generated by this user. The only workaround is to use any of the other aliasing mechanisms.
/etc/mail/aliases File
Any alias that is established in the /etc/mail/aliases file can be used by any user who knows the name of the alias and the host name of the system that contains the file. Distribution list formats in a local /etc/mail/aliases file adhere to the following format.
aliasname: value,value,value ...
aliasname is the name that the user uses when sending mail to this alias, and value is a valid email address.
If your network is not running a name service, the /etc/mail/aliases file of each system should contain entries for all mail clients. You can either edit the file on each system or edit the file on one system and copy it to each of the other systems.
The aliases in the /etc/mail/aliases file are stored in text form. When you edit the /etc/mail/aliases file, you need to run the newaliases program to recompile the database and make the aliases available in binary form to the sendmail program. For task information, refer to How to Set Up a Local Mail Alias File in Chapter 25, Mail Services (Tasks). Otherwise, you can use the AdminTool's Database Manager to administer the mail aliases that are stored in the local /etc files.
You can create aliases for only local names—a current host name or no host name. For example, an alias entry for user ignatz who has a mailbox on the system saturn would have the following entry in the /etc/mail/aliases file.
ignatz: ignatz@saturn
You should create an administrative account for each mail server. You create such an account by assigning a mailbox on the mail server to root and by adding an entry for root to the /etc/mail/aliases file. For example, if the system saturn is a mailbox server, add the entry root: sysadmin@saturn to the /etc/mail/aliases file.
Normally, only the root user can edit this file. However, when you use the Administration Tool, all users in group 14, which is the sysadmin group, can change the local file. Another option is to create the following entry.
aliasname: :include:/path/aliasfile
aliasname is the name that the user uses when sending mail, and /path/aliasfile is the full path to the file that contains the alias list. The alias file should include email entries, one entry on each line, and no other notations.
user1@host1
user2@host2
You can define additional mail files in /etc/mail/aliases to keep a log or a backup copy. The following entry stores all mail that is sent to aliasname in filename.
aliasname: /home/backup/filename
You can also route the mail to another process. The following example stores a copy of the mail message in filename and prints a copy.
aliasname: "|tee -a /home/backup/filename |lp"
For a task map, refer to Administering Mail Alias Files (Task Map) in Chapter 25, Mail Services (Tasks).
NIS aliases Map
All users in a local domain can use the entries that are in the NIS aliases map, because the sendmail program can use the NIS aliases map instead of the local /etc/mail/aliases files to determine mailing addresses. For more information, refer to the nsswitch.conf(4) man page.
Aliases in the NIS aliases map adhere to the following format.
The NIS aliases map should contain entries for all mail clients. In general, only the root user on the NIS master can change these entries. This type of alias might not be a good choice for aliases that are constantly changing, but such aliases can be useful if the aliases point to another alias file, as in the following syntax example.
aliasname: aliasname@host
aliasname is the name that the user uses when sending mail, and host is the host name for the server that contains an /etc/mail/alias file.
For task information, refer to How to Set Up an NIS mail.aliases Map in Chapter 25, Mail Services (Tasks).
NIS+ mail_aliases Table
The NIS+ mail_aliases table contains the names by which a system or person is known in the local domain. The sendmail program can use the NIS+ mail_aliases table, instead of the local /etc/mail/aliases files, to determine mailing addresses. Refer to the aliasadm(1M) and nsswitch.conf(4) man pages for more information.
Aliases in the NIS+ mail_aliases table adhere to the following format:
alias: expansion # ["options	" # "comments"]
Table 26–12 describes the four columns that are in an NIS+ mail_aliases table.
Table 26–12 Columns in the NIS+ mail_aliases Table
Column
Description
alias
The name of the alias
expansion
The value of the alias or a list of aliases as it would appear in a sendmail /etc/mail/aliases file
options
The column that is reserved for future use
comments
The column for comments about an individual alias
The NIS+ mail_aliases table should contain entries for all mail clients. You can list, create, modify, and delete entries in the NIS+ aliases table with the aliasadm command. To use the aliasadm command, you must be a member of the NIS+ group that owns the aliases table. For task information, refer to How to Manage Alias Entries in an NIS+ mail_aliases Table in Chapter 25, Mail Services (Tasks). Alternately, you can use the AdminTool's Database Manager to administer the NIS+ mail aliases.
Note –
If you are creating a new NIS+ aliases table, you must initialize the table before you create the entries. If the table exists, no initialization is needed.
