System Administration Guide: Resource Management and Network Services
Flags Used and Not Used to Compile sendmail
The following tables list the flags that are used when compiling the version of sendmail that is delivered with the Solaris 9 release. If your configuration requires other flags, you need to download the source and recompile the binary. You can find information about this process at http://www.sendmail.org.
Table 26–1 General sendmail Flags
Flag
Description
SOLARIS=20900
Support for the Solaris 9 operating environment.
MILTER
Support for the Mail Filter API.
NETINET6
Support for IPv6. This flag has been moved from conf.h to Makefile.
Table 26–2 Maps and Database Types
Flag
Description
NDBM
Support for ndbm databases
NEWDB
Support for db databases
USERDB
Support for the User database
NIS
Support for nis databases
NISPLUS
Support for nisplus databases
LDAPMAP
Support for LDAP maps
MAP_REGEX
Support for regular expression maps
Table 26–3 Solaris Flags
Flag
Description
SUN_EXTENSIONS
Support for Sun extensions that are included in sun_compat.o.
SUN_LOOKUP_MACRO
Support for the L and G configuration commands in sendmail.cf. Use of these commands is not recommended.
SUN_DEFAULT_VALUES
Support only for the default values in the Solaris flag, SUN_CONTENT_LENGTH.
SUN_INIT_DOMAIN
For backward compatibility, support for the use of NIS domain names to fully qualify the local host name. For more information, look for vendor-specific information in http://www.sendmail.org.
SUN_CONTENT_LENGTH
Support for the Content-Length: header in messages to files. For more information, look for vendor-specific information in http://www.sendmail.org.
SUN_SIMPLIFIED_LDAP
Support for a simplified LDAP API, which is specific to Sun. For more information, look for vendor-specific information in http://www.sendmail.org.
VENDOR_DEFAULT=VENDOR_SUN
Selects Sun as the default vendor.
The following table lists generic flags that are not used to compile the version of sendmail that is delivered with the Solaris 9 release.
Table 26–4 Generic Flags Not Used in the Solaris Version of sendmail
Flag
Description
SASL
Simple Authentication and Security Layer (RFC 2554)
STARTTLS
Transaction Level Security (RFC 2487)
To see a list of the flags that are used to compile sendmail, use the following command.
% /usr/lib/sendmail -bt -d0.10 < /dev/null
Note –
The preceding command does not list the flags that are specific to Sun.
