System Administration Guide: Resource Management and Network Services
Contents of the /etc/mail Directory
The following table shows the contents of the /etc/mail directory.
Name
Type
Description
Mail.rc
File
Default settings for the mailtool user agent.
aliases
File
Mail-forwarding information.
aliases.db
File
Default binary form of mail-forwarding information (created by running newaliases).
aliases.dir
File
Binary form of mail-forwarding information (created by running newaliases). Can still be used, but is no longer used by default in the Solaris 9 release.
aliases.pag
File
mailx.rc
File
Default settings for the mailx user agent.
main.cf
File
Sample configuration file for main systems.
relay-domains
File
List of all domains for which relaying is allowed. By default, only the local domain is allowed.
sendmail.cf
File
Configuration file for mail routing.
submit.cf
File
New configuration file for the mail submission program (MSP). For more information, refer to New Configuration File, submit.cf.
local-host-names
File
Optional file that you can create if the number of aliases for the mail host is too long.
helpfile
File
Help file that is used by the SMTP HELP command.
sendmail.pid
File
File that lists the PID of the listening daemon and is now in /var/run.
sendmail.st
File
sendmail statistics file. If this file is present, sendmail logs the amount of traffic through each mailer.
subsidiary.cf
File
Sample configuration file for subsidiary systems.
trusted-users
File
File that lists the users (one per line) who can be trusted to perform certain mail operations. By default, only root is in this file. Certain mail operations, when performed by untrusted users, result in the following warning, X-Authentication-Warning: header being added to a message.
