System Administration Guide: Resource Management and Network Services
Example-Using Multiple Files for NCA Logging
The logd_path_name string in ncalogd.conf can define multiple targets as the place to store the NCA log file. The second file is used when the first file is full. The following example shows how to select to write to the /var/nca/log file first and then use a raw partition.
# cat /etc/nca/ncalogd.conf
# NCA Logging Configuration File
status=enabled
logd_path_name="/var/nca/log /dev/rdsk/c0t0d0s7"
logd_file_size=1000000
