The following example displays RPC and NFS data for the client pluto.
$ nfsstat -c Client rpc: Connection oriented: calls badcalls badxids timeouts newcreds badverfs timers 1595799 1511 59 297 0 0 0 cantconn nomem interrupts 1198 0 7 Connectionless: calls badcalls retrans badxids timeouts newcreds badverfs 80785 3135 25029 193 9543 0 0 timers nomem cantsend 17399 0 0 Client nfs: calls badcalls clgets cltoomany 1640097 3112 1640097 0 Version 2: (46366 calls) null getattr setattr root lookup readlink read 0 0% 6589 14% 2202 4% 0 0% 11506 24% 0 0% 7654 16% wrcache write create remove rename link symlink 0 0% 13297 28% 1081 2% 0 0% 0 0% 0 0% 0 0% mkdir rmdir readdir statfs 24 0% 0 0% 906 1% 3107 6% Version 3: (1585571 calls) null getattr setattr lookup access readlink read 0 0% 508406 32% 10209 0% 263441 16% 400845 25% 3065 0% 117959 7% write create mkdir symlink mknod remove rmdir 69201 4% 7615 0% 42 0% 16 0% 0 0% 7875 0% 51 0% rename link readdir readdir+ fsstat fsinfo pathconf 929 0% 597 0% 3986 0% 185145 11% 942 0% 300 0% 583 0% commit 4364 0% Client nfs_acl: Version 2: (3105 calls) null getacl setacl getattr access 0 0% 0 0% 0 0% 3105 100% 0 0% Version 3: (5055 calls) null getacl setacl 0 0% 5055 100% 0 0% |
The output of the nfsstat -c command is described in Table 46–4.
Table 46–4 Output From the nfsstat -c Command
Field |
Description |
calls |
The total number of calls that were sent. |
badcalls |
The total number of calls that were rejected by RPC. |
retrans |
The total number of retransmissions. For this client, the number of retransmissions is less than 1 percent (10 timeouts out of 6888 calls). These retransmissions might be caused by temporary failures. Higher rates might indicate a problem. |
badxid |
The number of times that a duplicate acknowledgment was received for a single NFS request. |
timeout |
The number of calls that timed out. |
wait |
The number of times a call had to wait because no client handle was available. |
newcred |
The number of times the authentication information had to be refreshed. |
timers |
The number of times the time-out value was greater than or equal to the specified time-out value for a call. |
readlink |
The number of times a read was made to a symbolic link. If this number is high (over 10 percent), it could mean that there are too many symbolic links. |
The following example shows output from the nfsstat -m command.
pluto$ nfsstat -m /usr/man from pluto:/export/svr4/man Flags: vers=2,proto=udp,auth=unix,hard,intr,dynamic, rsize=8192, wsize=8192,retrans=5 Lookups: srtt=13 (32ms), dev=10 (50ms), cur=6 (120ms) All: srtt=13 (32ms), dev=10 (50ms), cur=6 (120ms) |
This output of the nfsstat -m command, which is displayed in milliseconds, is described in Table 46–5.
Table 46–5 Output From the nfsstat -m Command
Field |
Description |
srtt |
The smoothed average of the round-trip times |
dev |
The average deviations |
cur |
The current “expected” response time |
If you suspect that the hardware components of your network are creating problems, you need to look closely at the cabling and connectors.
