System Administration Guide: Resource Management and Network Services
Assigning Dynamic IP Addresses to Callers
Dynamic addressing involves the assignment to each caller of the IP address that is defined in /etc/ppp/options.ttyname. Dynamic addressing occurs on a per-serial port basis. Each time a call arrives over a particular serial line, the caller is given the IP address that is defined in the /etc/ppp/options.ttyname file for the serial interface that is handling the call.
For example, suppose a dial-in server has four serial interfaces that provide dial-up service to incoming calls:
With this addressing scheme, an incoming call on serial interface /dev/term/c is given the IP address 10.1.1.3 for the duration of the call. After the first caller hangs up, a later call that comes in over serial interface /dev/term/c is also given the IP address 10.1.1.3.
The advantages of dynamic addressing include the following:
