System Administration Guide: Resource Management and Network Services
Leased-Line PPP Overview
A hardwired, leased-line PPP configuration involves two peers that are connected by a link that consists of a switched or unswitched digital service leased from a provider. Solaris PPP 4.0 works over any full-duplex, point-to-point leased-line medium. Typically, a company rents a hardwired link from a network provider to connect to an ISP or other remote site.
Comparison of Dial-Up and Leased-Line Links
Both dial-up and leased-line links involve two peers that are connected by a communications medium. The next table summarizes the differences between the link types.
Leased Line
Dial-up Line
Always connected unless a system administrator or power failure takes it down
Initiated on demand, when a user tries to call a remote peer
Uses synchronous communications
Uses asynchronous communications
Rented from a provider
Uses existing telephone lines
Requires synchronous units
Uses less costly modems
Requires specialized interfaces
Uses standard serial interfaces that are included on most computers
Parts of a Leased-Line PPP Link
Figure 29–3 Basic Leased-Line Configuration
Graphic
The parts of the leased-line link include:
Note –
SONET is called an octet synchronous link. PPP uses a framing mechanism similar to asynchronous framing over a SONET line. PPP does not use the expected bit-synchronous protocol.
What Happens During Leased-Line Communications
On most types of leased lines, peers do not actually dial each other. Rather, a company purchases a leased-line service to explicitly connect between two fixed locations. Sometimes the two peers at either end of the leased line are at different physical locations of the same company. Another scenario is a company that sets up a router on a leased line that is connected to an ISP.
Leased lines are less commonly used than dial-up links, though the hardwired links are easier to set up. Hardwired links do not require chat scripts. Authentication is often not used because both peers are known to each other when a line is leased. After the two peers initiate PPP over the link, it stays active unless the leased line fails or either peer explicitly terminates the link.
A peer on a leased line that runs Solaris PPP 4.0 uses most of the same configuration files that define a dial-up link.
The following process occurs to initiate communication over the leased line:
  1. Each peer machine runs the pppd command as part of the booting process or other administrative script.
  2. The peers read their PPP configuration files.
  3. The peers negotiate communications parameters.
  4. An IP link is established.
