System Administration Guide: Resource Management and Network Services
Where to Go From Here
If you have followed all the procedures in this chapter, you have completed the configuration of the leased-line link.
Task
For Instructions
Instruct users to start communicating with machines on the Internet or other network that is served by the remote peer
Have users run telnet, ftp, rsh, or similar commands to reach machines outside the local network.
Fix problems on the link
Fixing Leased-Line Problems for troubleshooting information.
Learn more about the files and options used in this chapter
Using PPP Options in Files and on the Command Line.
