System Administration Guide: Resource Management and Network Services
Before You Set Up PPP Authentication
Setting up authentication at your site should be an integral part of your overall PPP strategy. Before implementing authentication, you should assemble the hardware, configure the software, and test the link to see if it works.
Table 30–5 Prerequisites Before Configuring Authentication
Information
For Instructions
Tasks for configuring a dial-up link
Chapter 31, Setting Up a Dial-up PPP Link (Tasks).
Tasks for testing the link
Chapter 35, Fixing Common Problems (Tasks).
Security requirements for your site
Your corporate security policy. If you do not have a policy, setting up PPP authentication gives you an opportunity to create a security policy.
Suggestions about whether to use PAP or CHAP at your site
Why Use PPP Authentication?. For more detailed information about these protocols, refer to Authenticating Callers on a Link.
