System Administration Guide: Resource Management and Network Services
Modem Chat Script for Calling an ISP
Use the next chat script as a template for calling an ISP from a dial-out machine with a US Robotics Courier modem.
ABORT   BUSY
ABORT   'NO CARRIER'
REPORT  CONNECT
TIMEOUT 10
"" AT&F1M0&M5S2=255
SAY     "Calling myisp\n"
TIMEOUT 60
OK      "ATDT1-123-555-1212"
CONNECT \c
\r \d\c
SAY "Connected; running PPP\n"
The following table describes the contents of the chat script.
Script Contents
Explanation
ABORT BUSY
Abort transmission if the modem receives this message from the opposite peer.
ABORT 'NO CARRIER'
REPORT CONNECT
Gather the CONNECT string from the modem and print it out.
TIMEOUT 10
Set initial timeout to 10 seconds. The modem's response should be immediate.
"" AT&F1M0M0M0M0&M5S2=255
M0 – Turn off the speaker during connect.
&M5 – Make the modem require error control.
S2=255 – Disable the TIES “+++” break sequence.
Display the message “Calling myisp” on the local machine.
TIMEOUT 60
Reset the timeout to 60 seconds to allow more time for link negotiation.
Call the remote peer by using the phone number 123-555-1212.
CONNECT \c
Wait for the CONNECT message from the opposite peer's modem.
\r \d\c
Wait until the end of the CONNECT message.
Display the informative message "Connected; running PPP" on the local machine.
