System Administration Guide: Resource Management and Network Services
/etc/ppp/options Configuration File
You use the /etc/ppp/options file to define global options for all PPP communications on the local machine. /etc/ppp/options is a privileged file. /etc/ppp/options should be owned by root, although pppd does not enforce this rule. Options that you define in /etc/ppp/options have precedence over definitions of the same options in all other files and the command line.
Typical options that you might use in /etc/ppp/options include the following:
Note –
The Solaris PPP 4.0 software does not include a default /etc/ppp/options file. pppd does not require the /etc/ppp/options file to work. But be aware that if a machine does not have an /etc/ppp/options file, only root can run pppd on that machine.
You must create /etc/ppp/options by using a text editor, as shown in How to Define Communications Over the Serial Line. If a machine does not require global options, you can create an empty /etc/ppp/options file. Then both root and regular users can run pppd on the local machine.
/etc/ppp/options.tmpl Template
The /etc/ppp/options.tmpl contains helpful comments about the /etc/ppp/options file plus three common options for the global /etc/ppp/options file.
lock
nodefaultroute
noproxyarp
Option
Definition
lock
Enables UUCP-style file locking
nodefaultroute
Specifies that no default route is defined
noproxyarp
Disallows proxyarp
To use /etc/ppp/options.tmpl as the global options file, rename /etc/ppp/options.tmpl to /etc/ppp/options. Then modify the file contents as needed by your site.
Where to Find Sample /etc/ppp/options Files
Table 36–2 Examples of the /etc/ppp/options File
Example /etc/ppp/options
For Instructions
For a dial-out machine
For a dial-in server
How to Define Communications Over the Serial Line (Dial-in Server)
For PAP support on a dial-in server
How to Add PAP Support to the PPP Configuration Files (Dial-in Server)
For PAP support on a dial-out machine
How to Add PAP Support to the PPP Configuration Files (Dial-out Machine)
For CHAP support on a dial-in server
How to Add CHAP Support to the PPP Configuration Files (Dial-in Server)
