System Administration Guide: Resource Management and Network Services
Using the nfsstat Command
# nfsstat -s
Server rpc:
Connection oriented:
calls      badcalls   nullrecv   badlen      xdrcall    dupchecks  dupreqs
11420263   0          0          0           0          1428274    19
Connectionless:
14569706   0          0          0           0          953332     1601
Server nfs:
calls      badcalls
24234967   226
Version 2: (13073528 calls)
null       getattr    setattr    root        lookup     readlink   read
138612 1%  1192059 9% 45676 0%   0 0%        9300029 71% 9872 0%   1319897 10%
wrcache    write      create     remove      rename     link       symlink
0 0%       805444 6%  43417 0%   44951 0%    3831 0%    4758 0%    1490 0%
mkdir      rmdir      readdir    statfs
2235 0%    1518 0%    51897 0%   107842 0%
Version 3: (11114810 calls)
null       getattr    setattr    lookup      access     readlink   read
141059 1%  3911728 35% 181185 1% 3395029 30% 1097018 9% 4777 0%   960503 8%
write      create     mkdir      symlink     mknod      remove     rmdir
763996 6%  159257 1%  3997 0%    10532 0%    26 0%      164698 1%  2251 0%
rename     link       readdir    readdirplus fsstat     fsinfo     pathconf
53303 0%   9500 0%    62022 0%   79512 0%    3442 0%    34275 0%   3023 0%
commit
73677 0%
Server nfs_acl:
Version 2: (1579 calls)
null       getacl     setacl     getattr     access
0 0%       3 0%       0 0%       1000 63%    576 36%
Version 3: (45318 calls)
null       getacl     setacl
0 0%       45318 100% 0 0%
The previous listing is an example of NFS server statistics. The first five lines relate to RPC and the remaining lines report NFS activities. In both sets of statistics, knowing the average number of badcalls or calls and the number of calls per week can help identify a problem. The badcalls value reports the number of bad messages from a client. This value can point out network hardware problems.
Some of the connections generate write activity on the disks. A sudden increase in these statistics could indicate trouble and should be investigated. For NFS version 2 statistics, the connections to note are setattr, write, create, remove, rename, link, symlink, mkdir, and rmdir. For NFS version 3 statistics, the value to watch is commit. If the commit level is high in one NFS server as compared to another almost identical server, check that the NFS clients have enough memory. The number of commit operations on the server grows when clients do not have available resources.
