This command generates information about the RPC service that is running on a system. You can also use it to change the RPC service. Many options are available with this command (see the rpcinfo(1M) man page). This is a shortened synopsis for some of the options that you can use with the command:
rpcinfo [ -m | -s ] [ hostname ]
rpcinfo -T transport hostname [ progname ]
rpcinfo [ -t | -u ] [ hostname ] [ progname ]
-m |
Displays a table of statistics of the rpcbind operations |
-s |
Displays a concise list of all registered RPC programs |
-T |
Displays information about services that use specific transports or protocols |
-t |
Probes the RPC programs that use TCP |
-u |
Probes the RPC programs that use UDP |
transport |
Selects the transport or protocol for the services |
hostname |
Selects the host name of the server you need information from |
progname |
Selects the RPC program to gather information about |
If no value is given for hostname, the local host name is used. You can substitute the RPC program number for progname, but many users can remember the name and not the number. You can use the -p option in place of the -s option on those systems that do not run the NFS version 3 software.
The data that is generated by this command can include the following:
The RPC program number
The version number for a specific program
The transport protocol that is being used
The name of the RPC service
The owner of the RPC service
This example gathers information on the RPC services that are running on a server. The text that is generated by the command is filtered by the sort command to make it more readable. Several lines that list RPC services have been deleted from the example.
% rpcinfo -s bee |sort -n program version(s) netid(s) service owner 100000 2,3,4 udp6,tcp6,udp,tcp,ticlts,ticotsord,ticots rpcbind superuser 100001 4,3,2 ticlts,udp,udp6 rstatd superuser 100002 3,2 ticots,ticotsord,tcp,tcp6,ticlts,udp,udp6 rusersd superuser 100003 3,2 tcp,udp,tcp6,udp6 nfs superuser 100005 3,2,1 ticots,ticotsord,tcp,tcp6,ticlts,udp,udp6 mountd superuser 100007 1,2,3 ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 ypbind superuser 100008 1 ticlts,udp,udp6 walld superuser 100011 1 ticlts,udp,udp6 rquotad superuser 100012 1 ticlts,udp,udp6 sprayd superuser 100021 4,3,2,1 tcp,udp,tcp6,udp6 nlockmgr superuser 100024 1 ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 status superuser 100029 3,2,1 ticots,ticotsord,ticlts keyserv superuser 100068 5 tcp,udp cmsd superuser 100083 1 tcp,tcp6 ttdbserverd superuser 100099 3 ticotsord autofs superuser 100133 1 ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 - superuser 100134 1 ticotsord tokenring superuser 100155 1 ticots,ticotsord,tcp,tcp6 smserverd superuser 100221 1 tcp,tcp6 - superuser 100227 3,2 tcp,udp,tcp6,udp6 nfs_acl superuser 100229 1 tcp,tcp6 metad superuser 100230 1 tcp,tcp6 metamhd superuser 100231 1 ticots,ticotsord,ticlts - superuser 100232 10 udp,udp6 sadmind superuser 100234 1 ticotsord gssd superuser 100235 1 tcp,tcp6 - superuser 100242 1 tcp,tcp6 metamedd superuser 100249 1 ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 - superuser 300326 4 tcp,tcp6 - superuser 300598 1 ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 - superuser 390113 1 tcp - unknown 805306368 1 ticots,ticotsord,ticlts,tcp,udp,tcp6,udp6 - superuser 1289637086 1,5 tcp - 26069 |
This example shows how to gather information about a particular RPC service by selecting a particular transport on a server.
% rpcinfo -t bee mountd program 100005 version 1 ready and waiting program 100005 version 2 ready and waiting program 100005 version 3 ready and waiting % rpcinfo -u bee nfs program 100003 version 2 ready and waiting program 100003 version 3 ready and waiting |
The first example checks the mountd service that is running over TCP. The second example checks the NFS service that is running over UDP.
