System Administration Guide: Resource Management and Network Services
How Autofs Starts the Navigation Process (Master Map)
The automount command reads the master map at system startup. Each entry in the master map is a direct or indirect map name, its path, and its mount options, as shown in Figure 16–2. The specific order of the entries is not important. automount compares entries in the master map with entries in the mount table to generate a current list.
Figure 16–2 Navigation Through the Master Map
Graphic
