System Administration Guide: Resource Management and Network Services
New Rule Sets
The following table lists the new rule sets and describes what they do.
Table 27–21 New Rule Sets
Set
Description
check_eoh
Correlates information that is gathered between headers and checks for missing headers. This rule set is used with the macro storage map and is called after all of the headers have been collected.
check_etrn
Uses the ETRN command (as check_rcpt uses RCPT).
check_expn
Uses the EXPN command (as check_rcpt uses RCPT).
check_vrfy
Uses the VRFY command (as check_rcpt uses RCPT).
The following list describes new rule set features.
