System Administration Guide: Resource Management and Network Services
Default Grade
You can define the binding of a default User-job-grade to a system job grade. You must use the keyword default as user job grade in the User-job-grade field of the Grades file and the system job grade that it is bound to. The Restrictions and ID fields should be defined as Any so that any user and any size job can be queued to this grade. Here is an example:
default a Any User Any
If you do not define the default user job grade, the built-in default grade Z is used. Because the restriction field default is Any, multiple occurrences of the default grade are not checked.
