System Administration Guide: Resource Management and Network Services
UUCP ASSERT Error Messages
The following table lists ASSERT error messages.
Table 40–11 ASSERT Error Messages
Error Message
Description or Action
CAN'T OPEN
An open() or fopen() failed.
CAN'T WRITE
A write(), fwrite(), fprint(), or similar command, failed.
CAN'T READ
A read(), fgets(), or similar command failed.
CAN'T CREATE
A creat() call failed.
CAN'T ALLOCATE
A dynamic allocation failed.
CAN'T LOCK
An attempt to make a LCK (lock) file failed. In some situations, this is a fatal error.
CAN'T STAT
A stat() call failed.
CAN'T CHMOD
A chmod() call failed.
CAN'T LINK
A link() call failed.
CAN'T CHDIR
A chdir() call failed.
CAN'T UNLINK
An unlink() call failed.
WRONG ROLE
This is an internal logic problem.
CAN'T MOVE TO CORRUPTDIR
An attempt to move some bad C. or X. files to the /var/spool/uucp/.Corrupt directory failed. The directory is probably missing or has wrong modes or owner.
CAN'T CLOSE
A close() or fclose() call failed.
FILE EXISTS
The creation of a C. or D. file is attempted, but the file exists. This error occurs when a problem arises with the sequence file access. Usually indicates a software error.
NO uucp SERVICE NUMBER
A TCP/IP call is attempted, but no entry is in /etc/services for UUCP.
BAD UID
The user ID is not in the password database. Check name service configuration.
BAD LOGIN_UID
Same as previous description.
BAD LINE
A bad line is in the Devices file. Not enough arguments on one or more lines.
SYSLST OVERFLOW
An internal table in gename.c overflowed. A single job attempted to talk to more than 30 systems.
TOO MANY SAVED C FILES
RETURN FROM fixline ioctl
An ioctl(2), which should never fail, failed. A system driver problem has occurred.
BAD SPEED
A bad line speed appears in the Devices or Systems file (Class or Speed field).
BAD OPTION
A bad line or option is in the Permissions file. It must be fixed immediately.
PKCGET READ
The remote machine probably hung up. No action need be taken.
PKXSTART
The remote machine aborted in a nonrecoverable way. This error can usually be ignored.
TOO MANY LOCKS
An internal problem has occurred. Contact your system vendor.
XMV ERROR
A problem with some file or directory has occurred. The spool directory is the probable cause, as the modes of the destinations were supposed to be checked before this process was attempted.
CAN'T FORK
An attempt to make a fork and exec failed. The current job should not be lost but will be attempted later (uuxqt). No action is needed.
