If your network is not connected to the Internet, you create your own named.ca file. To do this, you designate one of your servers to be the root server, then create a named.ca file on every DNS server pointing to that root server.
For example, suppose your domain is named private and you designate the machine ourroot as your non-Internet root server. The ourroot machine has an IP address of 192.1.1.10. Your named.ca files would then contain the line:
ourroot.private. 999999 IN A 192.1.1.10 |
Cache files also need an SOA record, NS records for each domain and subdomain, and A records for each server.
For example, suppose that in addition to ourroot you also had DNS name servers called ourmaster and ourslave. The named.ca files on all of your DNS servers would then look like the following.
; @ IN SOA ourroot.private. hermit.ourroot.private ( 1997071401 ; serial number (YYYYMMDD##) 10800 ; refresh after 3 hours 3600 ; retry after 1 hour 604800 ; expire after 1 week 86400 ) ; minimum TTL of 1 day ; ourroot.private. 999999 IN A 192.1.1.10 ; private. IN NS ourmaster.private. 1.1.192.in-addr.arpa IN NS ourmaster.private. ourprivate.private. IN A 192.1.1.1 ; private. IN NS ourslave.private. 1.1.192.in-addr.arpa IN NS ourslave.private. ourslave.private. IN A 192.1.1.2 |
See for a more complete discussion of setting up a domain that is not connected to the Internet.
