Solaris Common Desktop Environment: User's Guide
Graphical Workspace Manager Tasks
There are a number of tasks that you can perform using Graphical Workspace Manager:
Figure 7–2 Graphical Workspace Manager – Workspace Menu
Graphic
To Add a Workspace
  1. Choose Add Workspace from the Workspace menu.
  2. Enter a name in the Add Workspace dialog box.
  3. Click OK.
To Delete a Workspace
  1. Choose Delete Workspace from the Workspace menu.
  2. Choose the workspace to be deleted from the submenu.
To Rename a Workspace
  1. Choose Rename from the Workspace menu.
  2. From the submenu, select the workspace to be renamed.
  3. Enter the new name in the Rename Workspace dialog box.
  4. Click OK.
To Switch to a Different Workspace
  1. Choose Switch to Workspace from the Workspace menu.
  2. From the submenu, select the workspace to which you want to switch.
To Cascade All Windows in a Workspace
This task executes in the current workspace.
    Choose Cascade All Windows from the Workspace menu.
To Tile All Windows in a Workspace
  1. Choose Tile All Windows from the Workspace menu.
  2. From the submenu, choose Horizontal or Vertical.
To Open the Options Dialog
    Choose Options from the Workspace menu.
For further information on the Options Dialog, see Graphical Workspace Manager Options Dialog.
Figure 7–3 Graphical Workspace Manager — Window Menu
Graphic
To Minimize a Window
  1. Select a window in Graphical Workspace Manager.
  2. Choose Minimize from the Window menu.
To Close a Window
  2. Choose Close Window from the Window menu.
  3. (Optional) If the window you are closing is the only window that contains the application, a confirmation dialog will appear. Click OK, if you want to continue with closing the window.
To Terminate an Application
  1. Select an application window in Graphical Workspace Manager.
  2. Choose Terminate Application from the Window menu.
  3. In the confirmation dialog box, click OK.
To Move a Window to a Different Workspace
  1. Select a window in the Graphical Workspace Manager.
  2. Choose Move to Workspace from the Window menu.
  3. From the submenu, choose the workspace to which you want the window to move. You may also choose All Workspaces.
To Occupy Workspace(s)
  2. Choose Occupy Workspace from the Window menu.
  3. Choose the workspace(s) from the submenu.
    Multiple workspaces can be selected by pressing the Control key and selecting the additional workspaces.
  4. Click OK.
To Unoccupy Workspace
  2. Choose Unoccupy Workspace from the Window menu.
The Graphical Workspace Manager Options dialog box contains a number of options that can be set. They are:
Figure 7–4 Graphical Workspace Manager Options Dialog Box
Graphic
