Solaris Common Desktop Environment: User's Transition Guide
Moving Text and Objects
CDE has a clipboard facility, a drag-and-drop facility, and a duplication facility.
CDE provides a clipboard facility that can handle text and graphics simultaneously. Most CDE applications have an Edit menu that provides the standard clipboard items (Cut, Copy, and Paste). Cut, Copy and Paste are also available through the following key combinations.
Table 1-2 Clipboard Key Comparison
 Task or Feature OpenWindows Keys CDE Keys
 Cut Meta+X, or Cut Alt+X, or Control+Delete, or Cut
 Copy Meta+C, or Copy Alt+C, or Control+Insert, or Copy
 Paste Meta+V, or Paste Alt+V, or Shift+Insert, or Paste
Drag and Drop
As in OpenWindows, in CDE you can drag a selected object or text from one location to another inside the application, or from one application to another. Unlike OpenWindows, CDE does not enable you to drop objects on a minimized program icon, but it enables you to drop objects and text on the Front Panel.
Table 1-3 Drag and Drop Behavior
 Task or Feature OpenWindows Behavior CDE Behavior
 Drop an icon on the workspace Launches application Creates reference to item (original item still appears in File Manager)
 Drop text or files on message area in Mailer Inserts in message body Only supported for Compose window. Inserts text at insertion point and attaches files.
 Drop text or files in Attachments area in Mailer Attaches messages
Attaches files to message being composed
Attaches dropped text as text file
 Drop text into text window Text appears at drop point Text appears at insertion point (same as choosing Include from the File menu)
 Drop a file on a minimized application Application runs its default action (such as opening or printing the file) if it is of the appropriate type Not supported
See also "Chapter 1, Basic Skills" in Solaris Common Desktop Environment: User's Guide.
