Solaris 9 Installation Guide
Customizing the Solaris Installation on the Master System
After you install the Solaris operating environment on the master system by using any of the Solaris installation methods, you can add or delete software and modify system configuration information as necessary.
Note -
After you install the Web Start Flash archive on a clone system, some host-specific files are deleted and re-created for the clone machine. The installation program uses the sys-unconfig(1M) command and the sysidtool(1M) programs to delete and re-create the host-specific network configuration files. The files that are re-created include such files as /etc/hosts, /etc/defaultrouter, and /etc/defaultdomain.
