After you install the master system, create a Web Start Flash archive to use to install other systems.
Boot the master system and run it in as inactive a state as possible.
When possible, run the system in single-user mode. If that is not possible, shut down any applications that you want to archive and any applications that require extensive operating system resources.
You can create a Web Start Flash archive while the master system is running in multiuser mode, single-user mode, or while booted from one of the following:
Solaris 9 DVD.
Solaris 9 Software 1 of 2 CD.
An image of the Solaris 9 Software. If you are using CD media, the image could include the Solaris 9 Languages CD if needed.
To create the archive, use the flarcreate command.
# flarcreate -n name options path/filename |
name |
The name that you give the archive. The name you specify is the value of the content_name keyword. |
path |
The path to the directory in which you want to save the archive file. If you do not specify a path to save the archive, flarcreate saves the archive file in the current directory. |
filename |
The name of the archive file. |
For a list of command-line options, refer to "flarcreate".
If the archive creation is successful, the flarcreate command returns an exit code of 0. If the archive creation fails, the flarcreate command returns a nonzero exit code.
