Solaris 9 Installation Guide
Upgrading Metadevices and Volumes
To upgrade or install a flash archive on a new boot environment, the device must be a physical slice. If you have a boot environment that has a file system that is mounted either on a Solaris Volume Manager metadevice or a Veritas file system (VxFS) volume, the upgrade or installation of a flash archive fails. To upgrade or install a flash archive on such a boot environment, you must manually change the boot environment so that all slices are physical disk slices. You could use the lucreate command to create another boot environment or you could tear down the metadevices or volumes.
To use the lucreate command to make a copy of the boot environment, you would place the boot environment copy on physical disk slices. For example, if your current boot environment's disk configuration is the following:
root (/)
Mounted on /dev/md/dsk/d10
/usr
Mounted on /dev/md/dsk/d20
/var
Mounted on /dev/dsk/c0t3d0s0
Free slice
c0t4d0s0
Free slice
c0t4d0s3
Free slice
c0t4d0s4
You could then use the following lucreate command to copy the boot environment on physical disk slices. The boot environment could then be upgraded or installed with a flash archive. In this example the current boot environment is named, currentBE, and the new boot environment is named, nextBE.
# lucreate -s currentBE -n nextBE -m /:/dev/dsk/c0t4d0s0:ufs \
-m /usr:/dev/dsk/c0t4d0s3:ufs -m /var:/dev/dsk/c0t4d0s4:ufs
You would then be able to upgrade or install a flash archive on the new boot environment, activate it and then re-mirror or encapsulate it manually.
If you choose to manually tear down the metadevice or volume, you would need to do the following:
