You can also use finish scripts to customize files that are already installed on a system. For example, the finish script in Example 24-3 customizes the root environment by appending information to the .cshrc file in the root (/) directory.
#!/bin/sh # # Customize root's environment # echo "***adding customizations in /.cshrc" test -f a/.cshrc || { cat >> a/.cshrc <<EOF set history=100 savehist=200 filec ignoreeof prompt="\$user@`uname -n`> " alias cp cp -i alias mv mv -i alias rm rm -i alias ls ls -FC alias h history alias c clear unset autologout EOF } |
