Become superuser on the name server.
Change /var/yp/Makefile to add the local map.
Insert this shell procedure after the last variable.time shell procedure.
locale.time: $(DIR)/locale -@if [ -f $(DIR)/locale ]; then \ sed -e "/^#/d" -e s/#.*$$// $(DIR)/locale \ | awk '{for (i = 2; i<=NF; i++) print $$i, $$0}' \ | $(MAKEDBM) - $(YPDBDIR)/$(DOM)/locale.byname; \ touch locale.time; \ echo "updated locale"; \ if [ ! $(NOPUSH) ]; then \ $(YPPUSH) locale.byname; \ echo "pushed locale"; \ else \ : ; \ fi \ else \ echo "couldn't find $(DIR)/locale"; \ fi |
Find the string all: and, at the end of the list of variables, insert the word locale.
all: passwd group hosts ethers networks rpc services protocols \ netgroup bootparams aliases publickey netid netmasks c2secure \ timezone auto.master auto.home locale |
Near the end of the file, after the last entry of its type, insert the string locale: locale.time on a new line.
passwd: passwd.time group: group.time hosts: hosts.time ethers: ethers.time networks: networks.time rpc: rpc.time services: services.time protocols: protocols.time netgroup: netgroup.time bootparams: bootparams.time aliases: aliases.time publickey: publickey.time netid: netid.time passwd.adjunct: passwd.adjunct.time group.adjunct: group.adjunct.time netmasks: netmasks.time timezone: timezone.time auto.master: auto.master.time auto.home: auto.home.time locale: locale.time |
Save the file.
Create the file /etc/locale and make one entry for each domain or specific system:
locale domain_name |
Or
locale system_name |
Chapter 40, Locale Values (Reference) contains a list of valid locales.
For example, the following entry specifies that French is the default language that is used in the worknet.com domain:
fr worknet.com |
And the following entry specifies that Belgian French is the default locale that is used by a system named charlie:
fr_BE charlie |
Locales are available on the Solaris 9 DVD or Solaris 9 Software 1 of 2 CD.
# cd /var/yp; make |
Systems that are specified by domain or individually in the locale map are now set up to use the default locale. The default locale that you specified is used during installation and by the desktop after the system is rebooted.
