Solaris 9 Installation Guide
client_swap Profile Keyword
client_swap swap_size
client_swap defines the amount of swap space, swap_size in Mbytes, to allocate for each diskless client. If you do not specify client_swap in the profile, 32 Mbytes of swap space is allocated by default.
Example:
client_swap 64
The example specifies that each diskless client is to have a swap space of 64 Mbytes.
Note -
You can use client_swap only when system_type is specified as server.
How the Size of swap Is Determined
If a profile does not specify the size of swap, the JumpStart program determines the size of the swap space, based on the system's physical memory. Table 28-5 shows how the size of swap is determined during a custom JumpStart installation.
Table 28-5 Determining swap Size
Physical Memory (in Mbytes)
Swap Space (in Mbytes)
16-64
32
64-128
64
128-512
128
Greater than 512
256
The JumpStart program makes the size of swap no more than 20 percent of the disk where swap is located, unless the disk contains free space after laying out the other file systems. If free space exists, the JumpStart program allocates the free space to swap, and if possible, allocates the amount that is shown in Table 28-5.
Note -
Physical memory plus swap space must total a minimum of 32 Mbytes.
