Solaris 9 Installation Guide
To Continue Upgrading After a Failed Upgrade
The upgrade fails and the system cannot be soft-booted. The failure is for reasons beyond your control, such as a power failure or a network connection failure.
  1. Reboot the system from the Solaris 9 DVD, Solaris 9 Installation CD, the Solaris 9 Software 1 of 2 CD, or from the network.
  2. Choose the upgrade option for installation.
    The Solaris installation program determines if the system has been partially upgraded and continues the upgrade.
