Solaris 9 Installation Guide
To Start Solaris Live Upgrade Menus
Note -
When viewing the character interface remotely, such as over a tip line, you might need to set the TERM environment variable to VT220. Also, when using the Common Desktop Environment (CDE), set the value of the TERM variable to dtterm, rather than xterm.
  1. Log in as superuser.
  2. Type:
    # /usr/sbin/lu
    The Solaris Live Upgrade main menu is displayed.
    Figure 32-2 Solaris Live Upgrade Main Menu
    The screen capture shows Solaris Live Upgrade tasks and the Enter and Help keys.
