If you experience a failure while booting the new boot environment and can boot the original boot environment in single-user mode, use this procedure to fall back to the original boot environment.
If you need to boot from media or a net installation image, see "SPARC: To Fall Back to the Original Boot Environment by Using a DVD, CD, or Net Installation Image".
At the OK prompt, boot the machine to single-user state from the Solaris 9 DVD, Solaris 9 Installation CD, the network, or a local disk:
OK boot cdrom -s |
or
OK boot net -s |
or
OK boot device_name -s |
device_name |
Specifies the name of devices from where the system can boot, for example /dev/dsk/c0t0d0s0 |
Type:
# /sbin/luactivate BE_name |
BE_name |
Specifies the name of the boot environment to be activated |
If this command fails to display a prompt, proceed to "SPARC: To Fall Back to the Original Boot Environment by Using a DVD, CD, or Net Installation Image".
If the prompt is displayed, continue.
At the prompt, type:
Do you want to fallback to activate boot environment <disk name> (yes or no)? yes |
A message displays that the fallback activation is successful.
Reboot.
# init 6 |
The previous working boot environment becomes the active boot environment.
