Writing Device Drivers
Deferred Attach
open(9E) might be called on a minor device before attach(9E) has succeeded on the corresponding instance. open() must then return ENXIO, which will cause the system to attempt to attach the device. If the attach succeeds, the open is retried automatically.
Example 5–5 Example attach(9E) Entry Point
 * Attach an instance of the driver.  We take all the knowledge we
 * have about our board and check it against what has been filled in for
 * us from our FCode or from our driver.conf(4) file.
static int
xxattach(dev_info_t *dip, ddi_attach_cmd_t cmd)
    int instance;
    Pio *pio_p;
    ddi_device_acc_attr_t   da_attr;
    static int pio_validate_device(dev_info_t *);
    switch (cmd) {
    case DDI_ATTACH:
         * first validate the device conforms to a configuration this driver
         * supports
        if (pio_validate_device(dip) == 0)
            return (DDI_FAILURE);
         * Allocate a soft state structure for this device instance
         * Store a pointer to the device node in our soft state structure
         * and a reference to the soft state structure in the device
         * node.
        instance = ddi_get_instance(dip);
        if (ddi_soft_state_zalloc(pio_softstate, instance) != 0)
        pio_p = ddi_get_soft_state(pio_softstate, instance);
        ddi_set_driver_private(dip, (caddr_t)pio_p);
        pio_p->dip = dip;
         * Before adding the interrupt, get the interrupt block
         * cookie associated with the interrupt specification to
         * initialize the mutex used by the interrupt handler.
        if (ddi_get_iblock_cookie(dip, 0, &pio_p->iblock_cookie) !=
          DDI_SUCCESS) {
            ddi_soft_state_free(pio_softstate, instance);
        mutex_init(&pio_p->mutex, NULL, MUTEX_DRIVER, pio_p->iblock_cookie);
         * Now that the mutex is initialized, add the interrupt itself.
        if (ddi_add_intr(dip, 0, NULL, NULL, pio_intr, (caddr_t)instance) !=
          DDI_SUCCESS) {
            mutex_destroy(&pio_p>mutex);
         * Initialize the device access attributes for the register
         * mapping
        dev_acc_attr.devacc_attr_version = DDI_DEVICE_ATTR_V0;
        dev_acc_attr.devacc_attr_endian_flags = DDI_STRUCTURE_LE_ACC;
        dev_acc_attr.devacc_attr_dataorder = DDI_STRICTORDER_ACC;
         * Map in the csr register (register 0)
        if (ddi_regs_map_setup(dip, 0, (caddr_t *)&(pio_p->csr), 0,
            sizeof (Pio_csr), &dev_acc_attr, &pio_p->csr_handle) !=
            DDI_SUCCESS) {
            ddi_remove_intr(pio_p->dip, 0, pio_p->iblock_cookie);
            mutex_destroy(&pio_p->mutex);
         * Map in the data register (register 1)
        if (ddi_regs_map_setup(dip, 1, (caddr_t *)&(pio_p->data), 0,
            sizeof (uchar_t), &dev_acc_attr, &pio_p->data_handle) !=
            DDI_SUCCESS) {
            ddi_regs_map_free(&pio_p->csr_handle);
         * Create an entry in /devices for user processes to open(2)
         * This driver will create a minor node entry in /devices
         * of the form:  /devices/..../pio@X,Y:pio
        if (ddi_create_minor_node(dip, ddi_get_name(dip), S_IFCHR,
            instance, DDI_PSEUDO, 0) == DDI_FAILURE) {
            ddi_regs_map_free(&pio_p->data_handle);
         * reset device (including disabling interrupts)
        ddi_put8(pio_p->csr_handle, pio_p->csr, PIO_RESET);
         * report the name of the device instance which has attached
        ddi_report_dev(dip);
        return (DDI_SUCCESS);
    case DDI_RESUME:
    default:
Note –
The attach(9E) routine must not make any assumptions about the order of invocations on different device instances. The system may invoke attach(9E) concurrently on different device instances. The system may also invoke attach(9E) and detach(9E) concurrently on different device instances.
