Writing Device Drivers
The probe() Entry Point
For non-self-identifying devices, this entry point should determine whether the hardware device is present on the system.
For probe(9E) to determine whether the instance of the device is present, probe(9E) may need to do many of the things also commonly done by attach(9E). In particular, it may need to map the device registers.
Probing the device registers is device-specific. The driver often has to perform a series of tests of the hardware to assure that the hardware is really there. The test criteria must be rigorous enough to avoid misidentifying devices. For example, a device may appear to be present when in fact it is not, because a different device seems to behave like the expected device.
The test returns:
DDI_PROBE_SUCCESS if the probe was successful
DDI_PROBE_FAILURE if the probe failed
DDI_PROBE_DONTCARE if the probe was unsuccessful yet attach(9E) should still be called
DDI_PROBE_PARTIAL if the instance is not present now, but may be present in the future
For a given device instance, attach(9E) will not be called before probe(9E) has succeeded at least once on that device.
probe(9E) must free all the resources that it allocates, because it may be called multiple times; however, attach(9E) will not necessarily be called even if probe(9E) succeeds.
ddi_dev_is_sid(9F) may be used in a driver's probe(9E) routine to determine if the device is self-identifying. This is useful in drivers written for self-identifying and non-self-identifying versions of the same device.
Example 5–3 is a sample probe(9E) routine.
Example 5–3 probe(9E) Routine
static int
xxprobe(dev_info_t *dip)
    ddi_acc_handle_t dev_hdl;
    ddi_device_acc_attr_t dev_attr;
    Pio_csr *csrp;
    uint8_t csrval;
     * if the device is self identifying, no need to probe
    if (ddi_dev_is_sid(dip) == DDI_SUCCESS)
        return (DDI_PROBE_DONTCARE);
     * Initalize the device access attrributes and map in
     * the devices CSR register (register 0)
    dev_attr.devacc_attr_version = DDI_DEVICE_ATTR_V0;
    dev_attr.devacc_attr_endian_flags = DDI_STRUCTURE_LE_ACC;
    dev_attr.devacc_attr_dataorder = DDI_STRICTORDER_ACC;
    if (ddi_regs_map_setup(dip, 0, (caddr_t *)&csrp, 0, sizeof (Pio_csr),
        &dev_attr, &dev_hdl) != DDI_SUCCESS)
        return (DDI_PROBE_FAILURE);
     * Reset the device
     * Once the reset completes the CSR should read back
     * (PIO_DEV_READY | PIO_IDLE_INTR)
    ddi_put8(dev_hdl, csrp, PIO_RESET);
    csrval = ddi_get8(dev_hdl, csrp);
     * tear down the mappings and return probe success/failure
    ddi_regs_map_free(&dev_hdl);
    if ((csrval & 0xff) == (PIO_DEV_READY | PIO_IDLE_INTR))
        return (DDI_PROBE_SUCCESS);
    else
When the driver's probe(9E) routine is called, it does not know whether the device being probed exists on the bus. Therefore, it is possible that the driver may attempt to access device registers for a nonexistent device. A bus fault may be generated on some buses as a result.
Example 5–4 shows a probe(9E) routine that uses ddi_poke8(9F) to check for the existence of the device. ddi_poke8(9F) cautiously attempts to write a value to a specified virtual address, using the parent nexus driver to assist in the process where necessary. If the address is not valid, or the value cannot be written without an error occurring, an error code is returned. See also ddi_peek(9F).
In this example, ddi_regs_map_setup(9F) is used to map the device registers.
Example 5–4 probe(9E) Routine Using ddi_poke8(9F)
static int
    Pio_csr *csrp;
    uint8_t csrval;
    dev_attr.devacc_attr_version - DDI_DEVICE_ATTR_V0;
     * The bus can generate a fault when probing for devices which
     * do not exist.  Use ddi_poke8(9f) to handle any faults which
     * may occur.
     * Reset the device.  Once the reset completes the CSR should read
     * back (PIO_DEV_READY | PIO_IDLE_INTR)
    if (ddi_poke8(dip, csrp, PIO_RESET) != DDI_SUCCESS) {
        return (DDI_FAILURE);
    else
