This section gives the details of I/O request processing: from the application to the kernel, the driver, the device, the interrupt handler, and back to the user.
When a user thread issues a write(2) system call, it passes the address of a buffer in user space:
char buffer[] = "python"; count = write(fd, buffer, strlen(buffer) + 1);
The system builds a uio(9S) structure to describe this transfer by allocating an iovec(9S) structure and setting the iov_base field to the address passed to write(2), in this case, buffer. The uio(9S) structure is passed to the driver write(9E) routine (see Vectored I/O for more information about the uio(9S) structure).
The address in the iovec(9S) is in user space, not kernel space, and so is not guaranteed to be currently in memory. It is not even guaranteed to be a valid address. In either case, accessing a user address directly from the device driver or from the kernel could crash the system, so device drivers should never access user addresses directly. Instead, they should always use one of the data transfer routines in the Solaris 9 DDI/DKI that transfer data into or out of the kernel. These routines are able to handle page faults, either by bringing the proper user page in and continuing the copy transparently, or by returning an error on an invalid access.
Two routines commonly used are copyout(9F) to copy data from kernel space to user space and copyin(9F) to copy data from user space to kernel space. ddi_copyout(9F) and ddi_copyin(9F) operate similarly but are to be used in the ioctl(9E) routine. copyin(9F) and copyout(9F) can be used on the buffer described by each iovec(9S) structure, or uiomove(9F) can perform the entire transfer to or from a contiguous area of driver (or device) memory.
In character drivers, transfers are described by a uio(9S) structure. The uio(9S) structure contains information about the direction and size of the transfer, plus an array of buffers for one end of the transfer (the other end is the device).
The uio(9S) structure contains the following members:
iovec_t *uio_iov; /* base address of the iovec */ /* buffer description array */ int uio_iovcnt; /* the number of iovec structures */ off_t uio_offset; /* 32-bit offset into file where */ /* data is transferred from or to */ offset_t uio_loffset; /* 64-bit offset into file where */ /* data is transferred from or to */ uio_seg_t uio_segflg; /* identifies the type of I/O */ /* transfer: */ /* UIO_SYSSPACE: kernel <-> kernel */ /* UIO_USERSPACE: kernel <-> user */ short uio_fmode; /* file mode flags (not driver setable) */ daddr_t uio_limit; /* 32-bit ulimit for file (maximum */ /* block offset). not driver setable. */ diskaddr_t uio_llimit; /* 64-bit ulimit for file (maximum block */ /* block offset). not driver setable. */ int uio_resid; /* amount (in bytes) not */ /* transferred on completion */
A uio(9S) structure is passed to the driver read(9E) and write(9E) entry points. This structure is generalized to support what is called gather-write and scatter-read. When writing to a device, the data buffers to be written do not have to be contiguous in application memory. Similarly, when reading from a device into memory, the data comes off the device in a contiguous stream but can go into noncontiguous areas of application memory. See the readv(2), writev(2), pread(2), and pwrite(2) man pages for more information on scatter-gather I/O.
Each buffer is described by an iovec(9S) structure. This structure contains a pointer to the data area and the number of bytes to be transferred.
caddr_t iov_base; /* address of buffer */ int iov_len; /* amount to transfer */
The uio structure contains a pointer to an array of iovec(9S) structures. The base address of this array is held in uio_iov, and the number of elements is stored in uio_iovcnt.
The uio_offset field contains the 32-bit offset into the device at which the application needs to begin the transfer. uio_loffset is used for 64-bit file offsets. If the device does not support the notion of an offset, these fields can be safely ignored. The driver should interpret either uio_offset or uio_loffset (but not both). If the driver has set the D_64BIT flag in the cb_ops(9S) structure, it should use uio_loffset.
The uio_resid field starts out as the number of bytes to be transferred (the sum of all the iov_len fields in uio_iov) and must be set by the driver to the number of bytes not transferred before returning. The read(2) and write(2) system calls use the return value from the read(9E) and write(9E) entry points to determine if the transfer failed (and then return -1). If the return value indicates success, the system calls return the number of bytes requested minus uio_resid. If uio_resid is not changed by the driver, the read(2) and write(2) calls will return 0 (indicating end-of-file), even though all the data was transferred.
The support routines uiomove(9F), physio(9F), and aphysio(9F) update the uio(9S) structure directly, updating the device offset to account for the data transfer. When used with a seekable device, for which the concept of position is relevant, the driver does not need to adjust either the uio_offset or uio_loffset fields. I/O performed to a device in this manner is constrained by the maximum possible value of uio_offset or uio_loffset. An example of such a usage is raw I/O on a disk.
When performing I/O on a device on which the concept of position has no relevance, the driver can save uio_offset or uio_loffset, perform the I/O operation, then restore uio_offset or uio_loffset to the field's initial value. I/O performed to a device in this manner is not constrained by the maximum possible value of uio_offset or uio_loffset. An example of such a usage is I/O on a serial line.
The following example shows one way to preserve uio_loffset in the read(9E) function.
static int xxread(dev_t dev, struct uio *uio_p, cred_t *cred_p) { offset_t off; ... off = uio_p->uio_loffset; /* save the offset */ /* do the transfer */ uio_p->uio_loffset = off; /* restore it */ }
Data transfers can be synchronous or asynchronous depending on whether the entry point scheduling the transfer returns immediately or waits until the I/O has been completed.
The read(9E) and write(9E) entry points are synchronous entry points; they must not return until the I/O is complete. Upon return from the routines, the process knows whether the transfer has succeeded.
The aread(9E) and awrite(9E) entry points are asynchronous entry points. They schedule the I/O and return immediately. Upon return, the process issuing the request knows that the I/O has been scheduled and that the status of the I/O must be determined later. In the meantime, the process can perform other operations.
When an asynchronous I/O request is made to the kernel by a user process, the process is not required to wait while the I/O is in process. A process can perform multiple I/O requests and let the kernel handle the data transfer details. This is useful in applications such as transaction processing where concurrent programming methods can take advantage of asynchronous kernel I/O operations to increase performance or response time. Any performance boost for applications using asynchronous I/O, however, comes at the expense of greater programming complexity.
Data can be transferred using either programmed I/O or DMA. These data transfer methods can be used by either synchronous or asynchronous entry points, depending on the capabilities of the device.
Programmed I/O devices rely on the CPU to perform the data transfer. Programmed I/O data transfers are identical to other device register read and write operations. Various data access routines are used to read or store values to device memory.
uiomove(9F) can be used to transfer data to some programmed I/O devices. uiomove(9F) transfers data between the user space (defined by the uio(9S) structure) and the kernel. uiomove(9F) can handle page faults, so the memory to which data is transferred need not be locked down. It also updates the uio_resid field in the uio(9S) structure. Example 10–3 shows one way to write a ramdisk read(9E) routine. It uses synchronous I/O and relies on the presence of the following fields in the ramdisk state structure:
caddr_t ram; /* base address of ramdisk */ int ramsize; /* size of the ramdisk */
static int rd_read(dev_t dev, struct uio *uiop, cred_t *credp) { rd_devstate_t *rsp; rsp = ddi_get_soft_state(rd_statep, getminor(dev)); if (rsp == NULL) return (ENXIO); if (uiop->uio_offset >= rsp->ramsize) return (EINVAL); /* * uiomove takes the offset into the kernel buffer, * the data transfer count (minimum of the requested and * the remaining data), the UIO_READ flag, and a pointer * to the uio structure. */ return (uiomove(rsp->ram + uiop->uio_offset, min(uiop->uio_resid, rsp->ramsize - uiop->uio_offset), UIO_READ, uiop)); }
Another example of programmed I/O might be a driver writing data one byte at a time directly to the device's memory. Each byte is retrieved from the uio(9S) structure using uwritec(9F), then sent to the device. read(9E) can use ureadc(9F) to transfer a byte from the device to the area described by the uio(9S) structure.
static int xxwrite(dev_t dev, struct uio *uiop, cred_t *credp) { int value; struct xxstate *xsp; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); if the device implements a power manageable component, do this: pm_busy_component(xsp->dip, 0); if (xsp->pm_suspended) ddi_dev_is_needed(xsp->dip, normal power); while (uiop->uio_resid > 0) { /* * do the programmed I/O access */ value = uwritec(uiop); if (value == -1) return (EFAULT); ddi_put8(xsp->data_access_handle, &xsp->regp->data, (uint8_t)value); ddi_put8(xsp->data_access_handle, &xsp->regp->csr, START_TRANSFER); /* * this device requires a ten microsecond delay * between writes */ drv_usecwait(10); } pm_idle_component(xsp->dip, 0); return (0); }
Most character drivers use physio(9F) to do most of the setup work for DMA transfers in read(9E) and write(9E), as is shown in Example 10–5.
int physio(int (*strat)(struct buf *), struct buf *bp, dev_t dev, int rw, void (*mincnt)(struct buf *), struct uio *uio);
physio(9F) requires the driver to provide the address of a strategy(9E) routine. physio(9F) ensures that memory space is locked down (cannot be paged out) for the duration of the data transfer. This is necessary for DMA transfers because they cannot handle page faults. physio(9F) also provides an automated way of breaking a larger transfer into a series of smaller, more manageable ones. See minphys() Entry Point for more information.
static int xxread(dev_t dev, struct uio *uiop, cred_t *credp) { struct xxstate *xsp; int ret; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); ret = physio(xxstrategy, NULL, dev, B_READ, xxminphys, uiop); return (ret); } static int xxwrite(dev_t dev, struct uio *uiop, cred_t *credp) { struct xxstate *xsp; int ret; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); ret = physio(xxstrategy, NULL, dev, B_WRITE, xxminphys, uiop); return (ret); }
In the call to physio(9F), xxstrategy() is a pointer to the driver strategy routine. Passing NULL as the buf(9S) structure pointer tells physio(9F) to allocate a buf(9S) structure. If the driver must provide physio(9F) with a buf(9S) structure, getrbuf(9F) should be used to allocate one. physio(9F) returns zero if the transfer completes successfully, or an error number on failure. After calling strategy(9E), physio(9F) calls biowait(9F) to block until the transfer is completed or fails. The return value of physio(9F) is determined by the error field in the buf(9S) structure set by bioerror(9F).
Character drivers supporting aread(9E) and awrite(9E) use aphysio(9F) instead of physio(9F).
int aphysio(int (*strat)(struct buf *), int (*cancel)(struct buf *), dev_t dev, int rw, void (*mincnt)(struct buf *), struct aio_req *aio_reqp);
The address of anocancel(9F) is the only value that can currently be passed as the second argument to aphysio(9F).
aphysio(9F) requires the driver to pass the address of a strategy(9E) routine. aphysio(9F) ensures that memory space is locked down (cannot be paged out) for the duration of the data transfer. This is necessary for DMA transfers because they cannot handle page faults. aphysio(9F) also provides an automated way of breaking a larger transfer into a series of smaller, more manageable ones. See minphys() Entry Point for more information. Example 10–5 and Example 10–6 demonstrate that the aread(9E) and awrite(9E) entry points differ only slightly from the read(9E) and write(9E) entry points; the difference lies mainly in their use of aphysio(9F) instead of physio(9F).
static int xxaread(dev_t dev, struct aio_req *aiop, cred_t *cred_p) { struct xxstate *xsp; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); return (aphysio(xxstrategy, anocancel, dev, B_READ, xxminphys, aiop)); } static int xxawrite(dev_t dev, struct aio_req *aiop, cred_t *cred_p) { struct xxstate *xsp; xsp = ddi_get_soft_state(statep, getminor(dev)); if (xsp == NULL) return (ENXIO); return (aphysio(xxstrategy, anocancel, dev, B_WRITE, xxminphys,aiop)); }
In the call to aphysio(9F), xxstrategy() is a pointer to the driver strategy routine. aiop is a pointer to the aio_req(9S) structure and is also passed to aread(9E) and awrite(9E). aio_req(9S) describes where the data is to be stored in user space. aphysio(9F) returns zero if the I/O request is scheduled successfully or an error number on failure. After calling strategy(9E), aphysio(9F) returns without waiting for the I/O to complete or fail.
xxminphys() is a pointer to a function to be called by physio(9F) or aphysio(9F) to ensure that the size of the requested transfer does not exceed a driver-imposed limit. If the user requests a larger transfer, strategy(9E) will be called repeatedly, requesting no more than the imposed limit at a time. This is important because DMA resources are limited. Drivers for slow devices, such as printers, should be careful not to tie up resources for a long time.
Usually, a driver passes the address of the kernel function minphys(9F), but the driver can define its own xxminphys() routine instead. The job of xxminphys() is to keep the b_bcount field of the buf(9S) structure below a driver limit. There might be additional system limits that the driver should not circumvent, so the driver xxminphys() routine should call the system minphys(9F) routine after setting the b_bcount field and before returning.
#define XXMINVAL (512 << 10) /* 512 KB */ static void xxminphys(struct buf *bp) { if (bp->b_bcount > XXMINVAL) bp->b_bcount = XXMINVAL minphys(bp); }
The strategy(9E) routine originated in block drivers and is so called because it can implement a strategy for efficient queuing of I/O requests to a block device. A driver for a character-oriented device can also use a strategy(9E) routine. In the character I/O model presented here, strategy(9E) does not maintain a queue of requests, but rather services one request at a time.
In Example 10–8, the strategy(9E) routine for a character-oriented DMA device allocates DMA resources for synchronous data transfer and starts the command by programming the device register (see Chapter 8, Direct Memory Access (DMA) for a detailed description).
strategy(9E) does not receive a device number (dev_t) as a parameter; instead, this is retrieved from the b_edev field of the buf(9S) structure passed to strategy(9E).
static int xxstrategy(struct buf *bp) { minor_t instance; struct xxstate *xsp; ddi_dma_cookie_t cookie; instance = getminor(bp->b_edev); xsp = ddi_get_soft_state(statep, instance); ... if the device has power manageable components mark the device busy with pm_busy_components(9F), and then ensure that the device is powered up by calling ddi_dev_is_needed(9F). set up DMA resources with ddi_dma_alloc_handle(9F) and ddi_dma_buf_bind_handle(9F). xsp->bp = bp; /* remember bp */ program DMA engine and start command return (0); }
Although strategy(9E) is declared to return an int, it must always return zero.
On completion of the DMA transfer, the device generates an interrupt, causing the interrupt routine to be called. In Example 10–9, xxintr() receives a pointer to the state structure for the device that might have generated the interrupt.
static u_int xxintr(caddr_t arg) { struct xxstate *xsp = (struct xxstate *)arg; if (device did not interrupt) { return (DDI_INTR_UNCLAIMED); } if (error) { error handling } release any resources used in the transfer, such as DMA resources ddi_dma_unbind_handle(9F) and ddi_dma_free_handle(9F) /* notify threads that the transfer is complete */ biodone(xsp->bp); return (DDI_INTR_CLAIMED); }
The driver indicates an error by calling bioerror(9F). The driver must call biodone(9F) when the transfer is complete or after indicating an error with bioerror(9F).
