Writing Device Drivers
Programmed I/O Functions
Table B–13 Programmed I/O Functions
Function Name
Description
ddi_dev_nregs
return the number of register sets a device has
ddi_dev_regsize
return the size of a device's register
ddi_regs_map_setup
set up a mapping for a register address space
ddi_regs_map_free
free a previously mapped register address space
ddi_device_copy
copy data from one device register to another device register
ddi_device_zero
zero fill the device
ddi_check_acc_handle
check data access handle
ddi_get8
read 8–bit data from mapped memory, device register or DMA memory
ddi_get16
read 16–bit data from mapped memory, device register or DMA memory
ddi_get32
read 32–bit data from mapped memory, device register or DMA memory
ddi_get64
read 64–bit data from mapped memory, device register or DMA memory
ddi_put8
write 8–bit data to mapped memory, device register or DMA memory
ddi_put16
write 16–bit data to mapped memory, device register or DMA memory
ddi_put32
write 32–bit data to mapped memory, device register or DMA memory
ddi_put64
write 64–bit data to mapped memory, device register or DMA memory
ddi_rep_get8
read multiple 8–bit data from mapped memory, device register or DMA memory
ddi_rep_get16
read multiple 16–bit data from mapped memory, device register or DMA memory
ddi_rep_get32
read multiple 32–bit data from mapped memory, device register or DMA memory
ddi_rep_get64
read multiple 64–bit data from mapped memory, device register or DMA memory
ddi_rep_put8
write multiple 8–bit data to mapped memory, device register or DMA memory
ddi_rep_put16
write multiple 16–bit data to mapped memory, device register or DMA memory
ddi_rep_put32
write multiple 32–bit data to mapped memory, device register or DMA memory
ddi_rep_put64
write multiple 64–bit data to mapped memory, device register or DMA memory
ddi_peek8
cautiously read an 8–bit value from a location
ddi_peek16
cautiously read a 16–bit value from a location
ddi_peek32
cautiously read a 32–bit value from a location
ddi_peek64
cautiously read a 64–bit value from a location
ddi_poke8
cautiously write an 8–bit value to a location
ddi_poke16
cautiously write a 16–bit value to a location
ddi_poke32
cautiously write a 32–bit value to a location
ddi_poke64
cautiously write a 64–bit value to a location
The general programmed I/O functions above can always be used rather than the mem, io, and pci_config functions below. However, the below functions may be used as alternatives in cases where the type of access is known at compile time.
Table B–14 Alternate Access Mechanisms
Function Name
Description
ddi_io_get8
read 8-bit data from mapped device register in I/O space
ddi_io_get16
read 16-bit data from mapped device register in I/O space
ddi_io_get32
read 32-bit data from mapped device register in I/O space
ddi_io_put8
write 8-bit data to mapped device register in I/O space
ddi_io_put16
write 16-bit data to mapped device register in I/O space
ddi_io_put32
write 32-bit data to mapped device register in I/O space
ddi_io_rep_get8
read multiple 8-bit data from mapped device register in I/O space
ddi_io_rep_get16
read multiple 16-bit data from mapped device register in I/O space
ddi_io_rep_get32
read multiple 32-bit data from mapped device register in I/O space
ddi_io_rep_put8
write multiple 8-bit data to mapped device register in I/O space
ddi_io_rep_put16
write multiple 16-bit data to mapped device register in I/O space
ddi_io_rep_put32
write multiple 32-bit data to mapped device register in I/O space
ddi_mem_get8
read 8-bit data from mapped device in memory space or DMA memory
ddi_mem_get16
read 16-bit data from mapped device in memory space or DMA memory
ddi_mem_get32
read 32-bit data from mapped device in memory space or DMA memory
ddi_mem_get64
read 64-bit data from mapped device in memory space or DMA memory
ddi_mem_put8
write 8-bit data to mapped device in memory space or DMA memory
ddi_mem_put16
write 16-bit data to mapped device in memory space or DMA memory
ddi_mem_put32
write 32-bit data to mapped device in memory space or DMA memory
ddi_mem_put64
write 64-bit data to mapped device in memory space or DMA memory
ddi_mem_rep_get8
read multiple 8-bit data from mapped device in memory space or DMA memory
ddi_mem_rep_get16
read multiple 16-bit data from mapped device in memory space or DMA memory
ddi_mem_rep_get32
read multiple 32-bit data from mapped device in memory space or DMA memory
ddi_mem_rep_get64
read multiple 64-bit data from mapped device in memory space or DMA memory
ddi_mem_rep_put8
write multiple 8-bit data to mapped device in memory space or DMA memory
ddi_mem_rep_put16
write multiple 16-bit data to mapped device in memory space or DMA memory
ddi_mem_rep_put32
write multiple 32-bit data to mapped device in memory space or DMA memory
ddi_mem_rep_put64
write multiple 64-bit data to mapped device in memory space or DMA memory
pci_config_setup
setup access to PCI Local Bus Configuration space
pci_config_teardown
tear down access to PCI Local Bus Configuration space
pci_config_get8
read 8-bit data from the PCI Local Bus Configuration space
pci_config_get16
read 16-bit data from the PCI Local Bus Configuration space
pci_config_get32
read 32-bit data from the PCI Local Bus Configuration space
pci_config_get64
read 64-bit data from the PCI Local Bus Configuration space
pci_config_put8
write 8-bit data to the PCI Local Bus Configuration space
pci_config_put16
write 16-bit data to the PCI Local Bus Configuration space
pci_config_put32
write 32-bit data to the PCI Local Bus Configuration space
pci_config_put64
write 64-bit data to the PCI Local Bus Configuration space
Table B–15 Deprecated Programmed I/O Functions
Deprecated Function
Replacement
ddi_getb
ddi_get8
ddi_getl
ddi_get32
ddi_getll
ddi_get64
ddi_getw
ddi_get16
ddi_io_getb
ddi_io_get8
ddi_io_getl
ddi_io_get32
ddi_io_getw
ddi_io_get16
ddi_io_putb
ddi_io_put8
ddi_io_putl
ddi_io_put32
ddi_io_putw
ddi_io_put16
ddi_io_rep_getb
ddi_io_rep_get8
ddi_io_rep_getl
ddi_io_rep_get32
ddi_io_rep_getw
ddi_io_rep_get16
ddi_io_rep_putb
ddi_io_rep_put8
ddi_io_rep_putl
ddi_io_rep_put32
ddi_io_rep_putw
ddi_io_rep_put16
ddi_map_regs
ddi_regs_map_setup
ddi_mem_getb
ddi_mem_get8
ddi_mem_getl
ddi_mem_get32
ddi_mem_getll
ddi_mem_get64
ddi_mem_getw
ddi_mem_get16
ddi_mem_putb
ddi_mem_put8
ddi_mem_putl
ddi_mem_put32
ddi_mem_putll
ddi_mem_put64
ddi_mem_putw
ddi_mem_put16
ddi_mem_rep_getb
ddi_mem_rep_get8
ddi_mem_rep_getl
ddi_mem_rep_get32
ddi_mem_rep_getll
ddi_mem_rep_get64
ddi_mem_rep_getw
ddi_mem_rep_get16
ddi_mem_rep_putb
ddi_mem_rep_put8
ddi_mem_rep_putl
ddi_mem_rep_put32
ddi_mem_rep_putll
ddi_mem_rep_put64
ddi_mem_rep_putw
ddi_mem_rep_put16
ddi_peekc
ddi_peek8
ddi_peekd
ddi_peek64
ddi_peekl
ddi_peek32
ddi_peeks
ddi_peek16
ddi_pokec
ddi_poke8
ddi_poked
ddi_poke64
ddi_pokel
ddi_poke32
ddi_pokes
ddi_poke16
ddi_putb
ddi_put8
ddi_putl
ddi_put32
ddi_putll
ddi_put64
ddi_putw
ddi_put16
ddi_rep_getb
ddi_rep_get8
ddi_rep_getl
ddi_rep_get32
ddi_rep_getll
ddi_rep_get64
ddi_rep_getw
ddi_rep_get16
ddi_rep_putb
ddi_rep_put8
ddi_rep_putl
ddi_rep_put32
ddi_rep_putll
ddi_rep_put64
ddi_rep_putw
ddi_rep_put16
ddi_unmap_regs
ddi_regs_map_free
inb
ddi_io_get8
inl
ddi_io_get32
inw
ddi_io_get16
outb
ddi_io_put8
outl
ddi_io_put32
outw
ddi_io_put16
pci_config_getb
pci_config_get8
pci_config_getl
pci_config_get32
pci_config_getll
pci_config_get64
pci_config_getw
pci_config_get16
pci_config_putb
pci_config_put8
pci_config_putl
pci_config_put32
pci_config_putll
pci_config_put64
pci_config_putw
pci_config_put16
repinsb
ddi_io_rep_get8
repinsd
ddi_io_rep_get32
repinsw
ddi_io_rep_get16
repoutsb
ddi_io_rep_put8
repoutsd
ddi_io_rep_put32
repoutsw
ddi_io_rep_put16
