Writing Device Drivers
DMA Isolation
A defective device might initiate an improper DMA transfer over the bus. This data transfer could corrupt good data that was previously delivered. A device that fails might generate a corrupt address that can contaminate memory that does not even belong to its own driver.
In systems with an IOMMU, a device can write only to pages mapped as writable for DMA. Therefore, pages that are to be the target of DMA writes should be owned solely by one driver instance and not shared with any other kernel structure. While the page in question is mapped as writable for DMA, the driver should be suspicious of data in that page. The page must be unmapped from the IOMMU before it is passed beyond the driver, or before any validation of the data.
You can use ddi_umem_alloc(9F) to guarantee that a whole aligned page is allocated, or allocate multiple pages and ignore the memory below the first page boundary. You can find the size of an IOMMU page by using ddi_ptob(9F).
Alternatively, the driver can choose to copy the data into a safe part of memory before processing it. If this is done, the data must first be synchronized using ddi_dma_sync(9F).
Calls to ddi_dma_sync(9F) should specify SYNC_FOR_DEV before using DMA to transfer data to a device, and SYNC_FOR_CPU after using DMA to transfer data from the device to memory.
On some PCI-based systems with an IOMMU, devices may be able to use PCI dual address cycles (64-bit addresses) to bypass the IOMMU. This gives the device the potential to corrupt any region of main memory. Device drivers must not attempt to use such a mode and should disable it.
