GLD is a multi-threaded, clonable, loadable kernel module providing support for Solaris local area network device drivers. Local area network (LAN) device drivers in Solaris are STREAMS-based drivers that use DLPI to communicate with network protocol stacks. These protocol stacks use the network drivers to send and receive packets on a local area network. A network device driver must implement and conform to the requirements imposed by the DDI/DKI specification, STREAMS specification, DLPI specification, and programmatic interface of the device itself.
GLD implements most STREAMS and DLPI functionality required of a Solaris LAN driver. Several Solaris network drivers are implemented using GLD.
A Solaris network driver implemented using GLD is made up of two distinct parts: a generic component that deals with STREAMS and DLPI interfaces, and a device-specific component that deals with the particular hardware device. The device-specific module indicates its dependency on the GLD module (which is found at /kernel/misc/gld) and registers itself with GLD from within the driver's attach(9E) function. After it is successfully loaded, the driver is DLPI-compliant. The device-specific part of the driver calls gld(9F) functions when it receives data or needs some service from GLD. GLD makes calls into the gld(9E) entry points of the device-specific driver through pointers provided to GLD by the device-specific driver when it registered itself with GLD. The gld_mac_info(9S) structure is the main data interface between GLD and the device-specific driver.
The GLD facility currently supports devices of type DL_ETHER (ISO 8802–3, IEEE 802.3 protocol), DL_TPR (IEEE 802.5, Token Passing Ring), and DL_FDDI (ISO 9314–2, Fibre Distributed Data Interface). GLD drivers are expected to process fully formed MAC-layer packets and should not perform logical link control (LLC) handling.
In some cases, you might need or want to implement a full DLPI-compliant driver without using the GLD facility. This is true for devices that are not ISO 8802-style (IEEE 802) LAN devices, or where you need a device type or DLPI service not supported by GLD.
For devices designated type DL_ETHER, GLD provides support for both Ethernet V2 and ISO 8802-3 (IEEE 802.3) packet processing. Ethernet V2 enables a data link service user to access and use any of a variety of conforming data link service providers without special knowledge of the provider's protocol. A service access point (SAP) is the point through which the user communicates with the service provider.
Streams bound to SAP values in the range [0-255] are treated as equivalent and denote that the user wants to use 8802-3 mode. If the value of the SAP field of the DL_BIND_REQ is within this range, GLD computes the length (not including the 14-byte media access control (MAC) header) of each subsequent DL_UNITDATA_REQ message on that Stream and transmits 8802-3 frames having those lengths in the MAC frame header type fields. Such lengths never exceed 1500.
All frames received from the media that have a type field in the range [0-1500] are assumed to be 8802-3 frames and are routed up all open Streams that are in 8802-3 mode (those Streams bound to a SAP value in the [0-255] range). If more than one Stream is in 8802-3 mode, the incoming frame is duplicated and routed up each such Stream.
Streams bound to SAP values greater than 1500 (Ethernet V2 mode) receive incoming packets whose Ethernet MAC header type value exactly matches the value of the SAP to which the Stream is bound.
For media types DL_TPR and DL_FDDI, GLD implements minimal SNAP (Sub-Net Access Protocol) processing for any Stream bound to a SAP value greater than 255. SAP values in the range [0-255] are LLC SAP values and are carried naturally by the media packet format. SAP values greater than 255 require a SNAP header, subordinate to the LLC header, to carry the 16-bit Ethernet V2-style SAP value.
SNAP headers are carried under LLC headers with destination SAP 0xAA. For outgoing packets with SAP values greater than 255, GLD creates an LLC+SNAP header that always looks like:
AA AA 03 00 00 00 XX XX
where ``XX XX'' represents the 16-bit SAP, corresponding to the Ethernet V2 style ``type.'' This is the only class of SNAP header supported—non-zero OUI (organizational unique identifier) fields and LLC control fields other than 03 are considered to be LLC packets with SAP 0xAA. Clients wanting to use SNAP formats other than this one must use LLC and bind to SAP 0xAA.
Incoming packets are examined to ascertain whether they conform to the format shown above. Packets that conform to this format are matched to any Streams bound to the packet's 16-bit SNAP type, as well as being considered to match the LLC SNAP SAP 0xAA.
Packets received for any LLC SAP are passed up all Streams that are bound to an LLC SAP, as described for media type DL_ETHER.
For type DL_TPR devices, GLD implements minimal support for source routing. Source routing enables a station that is sending a packet across a bridged medium to specify (in the packet MAC header) routing information that determines the route that the packet will take through the network.
Functionally, the source routing support provided by GLD learns routes, solicits and responds to requests for information about possible multiple routes, and selects among available routes. It adds Routing Information Fields to the MAC headers of outgoing packets and recognizes such fields in incoming packets.
GLD's source routing support does not implement the full Route Determination Entity (RDE) specified in Section 9 of ISO 8802-2 (IEEE 802.2). However, it can interoperate with any such implementations that might exist in the same (or a bridged) network.
GLD implements both Style 1 and Style 2 DLPI providers. A physical point of attachment (PPA) is the point at which a system attaches itself to a physical communication medium. All communication on that physical medium funnels through the PPA. The Style 1 provider attaches the Stream to a particular PPA based on the major/minor device that has been opened. The Style 2 provider requires the DLS (data link service) user to explicitly identify the desired PPA using DL_ATTACH_REQ. In this case, open(9E) creates a Stream between the user and GLD, and DL_ATTACH_REQ subsequently associates a particular PPA with that Stream. Style 2 is denoted by a minor number of zero. If a device node whose minor number is not zero is opened, Style 1 is indicated and the associated PPA is the minor number minus 1. In both Style 1 and Style 2 opens, the device is cloned.
GLD implements several DLPI primitives. The DL_INFO_REQ primitive requests information about the DLPI Stream. The message consists of one M_PROTO message block. GLD returns device-dependent values in the DL_INFO_ACK response to this request, based on information the GLD-based driver specified in the gldm_mac_info(9S) structure passed to gld_register(). However, GLD returns the following values on behalf of all GLD-based drivers:
Service mode is DL_CLDLS — GLD implements connectionless-mode service
Provider style is DL_STYLE1 or DL_STYLE2, depending on how the Stream was opened
No optional Quality of Service (QOS) support is present and the QOS fields are zero
Contrary to the DLPI specification, GLD returns the device's correct address length and broadcast address in DL_INFO_ACK even before the Stream has been attached to a PPA.
The DL_ATTACH_REQ primitive is used to associate a PPA with a Stream. This request is needed for Style 2 DLS providers to identify the physical medium over which the communication will transpire. Upon completion, the state changes from DL_UNATTACHED to DL_UNBOUND. The message consists of one M_PROTO message block. This request is not permitted when using the driver in Style 1 mode; Streams opened using Style 1 are already attached to a PPA by the time the open completes.
The DL_DETACH_REQ primitive requests to detach the PPA from the Stream. This is only allowed if the Stream was opened using Style 2.
The DL_BIND_REQ and DL_UNBIND_REQ primitives bind and unbind a DLSAP (data link service access point) to the Stream. The PPA associated with a Stream will have completed initialization before completion of the processing of the DL_BIND_REQ on that Stream. Binding multiple Streams to the same SAP is allowed; each such Stream receives a copy of any packets received for that SAP.
The DL_ENABMULTI_REQ and DL_DISABMULTI_REQ primitives enable and disable reception of individual multicast group addresses. An application or other DLS user is permitted to create or modify a set of multicast addresses on a per-Stream basis by iterative use of these primitives. The Stream must be attached to a PPA for these primitives to be accepted.
The DL_PROMISCON_REQ and DL_PROMISCOFF_REQ primitives enable and disable promiscuous mode on a per-Stream basis, either at a physical level or at the SAP level. The DL Provider routes all received messages on the media to the DLS user until either a DL_DETACH_REQ or a DL_PROMISCOFF_REQ is received or the Stream is closed. You can specify physical level promiscuous reception of all packets on the medium or of multicast packets only.
The Stream must be attached to a PPA for these promiscuous mode primitives to be accepted.
The DL_UNITDATA_REQ primitive is used to send data in a connectionless transfer. Because this is an unacknowledged service, there is no guarantee of delivery. The message consists of one M_PROTO message block followed by one or more M_DATA blocks containing at least one byte of data.
The DL_UNITDATA_IND type is used when a packet is received and is to be passed upstream. The packet is put into an M_PROTO message with the primitive set to DL_UNITDATA_IND.
The DL_PHYS_ADDR_REQ primitive requests the MAC address currently associated with the PPA attached to the Stream. The address is returned by the DL_PHYS_ADDR_ACK primitive. When using Style 2, this primitive is only valid following a successful DL_ATTACH_REQ.
The DL_SET_PHYS_ADDR_REQ primitive changes the MAC address currently associated with the PPA attached to the Stream. This primitive affects all other current and future Streams attached to this device. Once changed, all Streams currently or subsequently opened and attached to this device will obtain this new physical address. The new physical address remains in effect until this primitive is used to change the physical address again or the driver is reloaded.
The superuser is allowed to change the physical address of a PPA while other Streams are bound to the same PPA.
The DL_GET_STATISTICS_REQ primitive requests a DL_GET_STATISTICS_ACK response containing statistics information associated with the PPA attached to the Stream. Style 2 Streams must be attached to a particular PPA using DL_ATTACH_REQ before this primitive can succeed.
GLD implements the ioctl ioc_cmd function described below. If GLD receives an ioctl command that it does not recognize, it passes it to the device-specific driver's gldm_ioctl() routine, as described in gld(9E).
The DLIOCRAW ioctl function is used by some DLPI applications, most notably the snoop(1M) command. The DLIOCRAW command puts the Stream into a raw mode, which causes the driver to pass full MAC-level incoming packets upstream in M_DATA messages instead of transforming them into the DL_UNITDATA_IND form that is normally used for reporting incoming packets. Packet SAP filtering is still performed on Streams that are in raw mode. If a Stream user wants to receive all incoming packets, it must also select the appropriate promiscuous mode or modes. After successfully selecting raw mode, the application is also allowed to send fully formatted packets to the driver as M_DATA messages for transmission. DLIOCRAW takes no arguments. Once enabled, the Stream remains in this mode until closed.
GLD-based drivers must include the header file <sys/gld.h>.
GLD-based drivers must be linked with the -N“misc/gld” option:
%ld -r -N"misc/gld" xx.o -o xx
GLD implements the open(9E) and close(9E) functions and the required STREAMS put(9E) and srv(9E) functions on behalf of the device-specific driver. GLD also implements the getinfo(9E) function for the driver.
The mi_idname element of the module_info(9S) structure is a string specifying the name of the driver. This must exactly match the name of the driver module as it exists in the file system.
The read-side qinit(9S) structure should specify the following elements:
NULL
gld_rsrv
gld_open
gld_close
The write-side qinit(9S) structure should specify these elements:
gld_wput
gld_wsrv
NULL
NULL
The devo_getinfo element of the dev_ops(9S) structure should specify gld_getinfo as the getinfo(9E) routine.
The driver's attach(9E) function does all the work of associating the hardware-specific device driver with the GLD facility and preparing the device and driver for use.
The attach(9E) function allocates a gld_mac_info(9S) (``macinfo'') structure using gld_mac_alloc(). The driver usually needs to save more information per device than is defined in the macinfo structure. It should allocate the additional required data structure and save a pointer to it in the gldm_private member of the gld_mac_info(9S) structure.
The attach(9E) routine must initialize the macinfo structure as described in gld_mac_info(9S) and then call gld_register() to link the driver with the GLD module. The driver should map registers if necessary and be fully initialized and prepared to accept interrupts before calling gld_register(). The attach(9E) function should add interrupts but not enable the device to generate them. The driver should reset the hardware before calling gld_register() to ensure it is quiescent. The device must not be started or put into a state where it might generate an interrupt before gld_register() is called. That will be done later when GLD calls the driver's gldm_start() entry point, described in the gld(9E) man page. After gld_register() succeeds, the gld(9E) entry points might be called by GLD at any time.
The attach(9E) routine should return DDI_SUCCESS if gld_register() succeeds. If gld_register() fails, it returns DDI_FAILURE, and the attach(9E) routine should deallocate any resources it allocated before calling gld_register() and then also return DDI_FAILURE. Under no circumstances should a failed macinfo structure be reused; it should be deallocated using gld_mac_free().
The detach(9E)function should attempt to unregister the driver from GLD by calling gld_unregister() (described in gld(9F) man page). The detach(9E) routine can get a pointer to the needed gld_mac_info(9S) structure from the device's private data using ddi_get_driver_private(9F). gld_unregister() checks certain conditions that could require that the driver not be detached. If the checks fail, gld_unregister() returns DDI_FAILURE, in which case the driver's detach(9E) routine must leave the device operational and return DDI_FAILURE.
If the checks succeed, gld_unregister() ensures that the device interrupts are stopped (calling the driver's gldm_stop() routine if necessary), unlinks the driver from the GLD framework, and returns DDI_SUCCESS. In this case, the detach(9E) routine should remove interrupts, deallocate any data structures allocated in the attach(9E) routine (using gld_mac_free() to deallocate the macinfo structure), and return DDI_SUCCESS. The routine must remove the interrupt before calling gld_mac_free().
Solaris network drivers must implement statistics variables. GLD itself tallies some network statistics, but other statistics must be counted by each GLD-based driver. GLD provides support for GLD-based drivers to report a standard set of network driver statistics. Statistics are reported by GLD using the kstat(7D) and kstat(9S) mechanisms. The DL_GET_STATISTICS_REQ DLPI command can also be used to retrieve the current statistics counters. All statistics are maintained as unsigned, and all are 32 bits unless otherwise noted.
GLD maintains and reports the following statistics.
Total bytes successfully received on the interface (64 bits)
Total bytes requested to be transmitted on the interface (64 bits)
Total packets successfully received on the interface (64 bits)
Total packets requested to be transmitted on the interface (64 bits)
Multicast packets successfully received, including group and functional addresses (long
Multicast packets requested to be transmitted, including group and functional addresses (long
Broadcast packets successfully received (long
Broadcast packets requested to be transmitted (long
Valid received packets not accepted by any Stream (long
Packets discarded on output because transmit buffer was busy, or no buffer could be allocated for transmit (long
Number of times a received packet could not be put up a Stream because the queue was flow-controlled (long
Times transmit was retried after having been delayed due to lack of resources (long
Current ``promiscuous'' state of the interface (string)
The device-dependent driver counts the following statistics, keeping track of them in a private per-instance structure. When GLD is asked to report statistics, it calls the driver's gldm_get_stats() entry point (as described in the gldm_get_stats(9E) man page) to update the device-specific statistics in the gld_stats(9S) structure. GLD then reports the updated statistics using the named statistics variables shown below.
Current estimated bandwidth of the interface in bits per second (64 bits)
Current media type in use by the device (string)
Times interrupt handler was called and claimed the interrupt (long
Number of times a valid incoming packet was known to have been discarded because no buffer could be allocated for receive (long
Total packets received that could not be processed because they contained errors (long
Total packets that were not successfully transmitted because of errors (long
Packets known to have been dropped by the hardware on receive (long
Times FIFO underflowed on transmit (long
Times receiver overflowed during receive (long
The following group of statistics applies to networks of type DL_ETHER. These statistics are maintained by device-specific drivers of that type, as shown previously.
Packets received with framing errors (not an integral number of octets) (long
Packets received with CRC errors (long
Current duplex mode of the interface (string)
Number of times carrier was lost or never detected on a transmission attempt (long
Ethernet collisions during transmit (long
Frames where excess collisions occurred on transmit, causing transmit failure (long
Number of times a transmit collision occurred late (after 512 bit times) (long
Packets without collisions where first transmit attempt was delayed because the medium was busy (long
Packets successfully transmitted with exactly one collision
Packets successfully transmitted with multiple collisions
Number of times SQE test error was reported
Packets encountering transmit MAC failures, except carrier and collision failures
Packets received with MAC errors, except align_errors, fcs_errors, and toolong_errors
Packets received larger than the maximum permitted length
Packets received smaller than the minimum permitted length (long
The following group of statistics applies to networks of type DL_TPR; these are maintained by device-specific drivers of that type, as shown above.
Packets received with non-data bits or FCS errors
Number of times an absence of transitions for five half-bit timers was detected
Number of times loss of signal condition on the ring was detected
Number of times an AMP or SMP frame, in which A is equal to C is equal to 0, was followed by another such SMP frame without an intervening AMP frame
Number of times the station recognized an internal error
Number of times the TRR timer expired during transmit
Number of times a frame addressed to this station was received with the FS field `A' bit set to 1
Number of times the station acting as the active monitor recognized an error condition that needed a token transmitted
Number of times the frequency of the incoming signal differed from the expected frequency
The following group of statistics applies to networks of type DL_FDDI; these are maintained by device-specific drivers of that type, as shown above
Frames detected in error by this MAC that had not been detected in error by another MAC
Frames received with format errors such that the frame was stripped
Number of tokens received (total of non-restricted and restricted)
Number of times that TVX has expired
Number of TRT expirations since this MAC was reset or a token was received
Number of times the ring has entered the ``Ring Operational'' state from the ``Ring Not Operational'' state
