The driver must first obtain the iblock cookie to initialize mutexes used in the driver handler. Only after those mutexes have been initialized can the interrupt handler be added.
i = ddi_get_iblock_cookie(dip, 0, &isp->iblock_cookie}; if (i != DDI_SUCCESS) { do error recovery return (DDI_FAILURE); } mutex_init(&isp->mutex, "isp_mutex", MUTEX_DRIVER, (void *)isp->iblock_cookie); i = ddi_add_intr(dip, 0, &isp->iblock_cookie, 0, isp_intr, (caddr_t)isp); if (i != DDI_SUCCESS) { do error recovery return (DDI_FAILURE); }
The driver should determine if a high-level interrupt handler is required. If a high-level handler is required and the driver is not coded to provide one, rewrite the driver to include either a high-level interrupt or fail the attach. See Handling High-Level Interrupts for a description of high-level interrupt handling.
