Writing Device Drivers
HBA Configuration Properties
When attaching an instance of an HBA device, scsi_hba_attach_setup(9F) creates a number of SCSI configuration parameter properties for that HBA instance. A particular property is created only if there is no existing property of the same name already attached to the HBA instance, permitting a default property value to be overridden in an HBA configuration file.
An HBA driver must use ddi_prop_get_int(9F) to retrieve each property. The HBA driver then modifies (or accepts the default value of) the properties to configure its specific operation.
scsi-reset-delay Property
The scsi-reset-delay property is an integer specifying the SCSI bus or device reset delay recovery time in milliseconds.
scsi-options Property
The scsi-options property is an integer specifying a number of options through individually defined bits. The bits in scsi_options are:
Per-target scsi-options
An HBA driver might support a per-target scsi-options feature in the following format:
    target<n>-scsi-options=<hex value>
In this example, < n> is the target ID. If the per-target scsi-options property is defined for a particular target, the HBA driver uses the value of the per-target scsi-options property for that target rather than the per-HBA driver instance scsi-options property. This can provide more precise control if, for example, synchronous data transfer needs to be disabled for just one particular target device. The per-target scsi-options property can be defined in the driver.conf(4) file.
Here is an example of a per-target scsi-options property definition to disable synchronous data transfer for target device 3:
    target3-scsi-options=0x2d8
