Writing Device Drivers
gld_sched() Function
void gld_sched(gld_mac_info_t * macinfo);
gld_sched() is called by the device driver to reschedule stalled outbound packets. Whenever the driver's gldm_send() routine has returned GLD_NORESOURCES, the driver must later call gld_sched() to inform the GLD framework that it should retry the packets that previously could not be sent. gld_sched() should be called as soon as possible after resources are again available, to ensure that GLD resumes passing outbound packets to the driver's gldm_send() routine in a timely way. (If the driver's gldm_stop() routine is called, the driver is absolved from this obligation until it later again returns GLD_NORESOURCES from its gldm_send() routine; however, extra calls to gld_sched() will not cause incorrect operation.)
