Solaris Modular Debugger Guide
Freed Buffer Checking: 0xdeadbeef
When the KMF_DEADBEEF (0x2) bit is set in the flags field of a kmem_cache, the allocator tries to make memory corruption easy to detect by writing a special pattern into all freed buffers. This pattern is 0xdeadbeef. Since a typical region of memory contains both allocated and freed memory, sections of each kind of block will be interspersed; here is an example from the “kmem_alloc_24” cache:
0x70a9add8:     deadbeef        deadbeef
0x70a9ade0:     deadbeef        deadbeef
0x70a9ade8:     deadbeef        deadbeef
0x70a9adf0:     feedface        feedface
0x70a9adf8:     70ae3260        8440c68e
0x70a9ae00:     5               4ef83
0x70a9ae08:     0               0
0x70a9ae10:     1               bbddcafe
0x70a9ae18:     feedface        139d
0x70a9ae20:     70ae3200        d1befaed
0x70a9ae28:     deadbeef        deadbeef
0x70a9ae30:     deadbeef        deadbeef
0x70a9ae38:     deadbeef        deadbeef
0x70a9ae40:     feedface        feedface
0x70a9ae48:     70ae31a0        8440c54e
The buffer beginning at 0x70a9add8 is filled with the 0xdeadbeef pattern, which is an immediate indication that the buffer is currently free. At 0x70a9ae28 another free buffer begins; at 0x70a9ae00 an allocated buffer is located between them.
Note –
You might have observed that there are some holes on this picture, and that 3 24–byte regions should occupy only 72 bytes of memory, instead of the 120 bytes shown here. This discrepancy is explained in the next section Redzone: 0xfeedface.
