Solaris Modular Debugger Guide
Walkers
binding_hash
Given the address of an array of kernel binding hash table entries (struct bind **), walk all entries in the hash table and return the address of each struct bind.
devinfo
First, iterate over the parents of the given devinfo and return them in order of seniority from most to least senior. Second, return the given devinfo itself. Third, iterate over the children of the given devinfo in order of seniority from most to least senior. The dev_info struct is defined in <sys/ddi_impldefs.h>.
devinfo_children
First, return the given devinfo, then iterate over the children of the given devinfo in order of seniority from most to least senior. The dev_info struct is defined in <sys/ddi_impldefs.h>.
devinfo_parents
Iterate over the parents of the given devinfo in order of seniority from most to least senior, and then return the given devinfo. The dev_info struct is defined in <sys/ddi_impldefs.h>.
devi_next
Iterate over the siblings of the given devinfo. The dev_info struct is defined in <sys/ddi_impldefs.h>.
devnames
Iterate over the entries in the devnames array. This structure is defined in <sys/autoconf.h>.
softstate
Given a softstate pointer (see ddi_soft_state_init(9F)) display all non-NULL pointers to driver state structures.
softstate_all
Given a softstate pointer (see ddi_soft_state_init(9F)) display all pointers to driver state structures. Note that the pointers for unused instances will be NULL.
