Solaris Modular Debugger Guide
Loopback File System Debugging Support (lofs)
The lofs module provides debugging support for the lofs(7FS) file system.
dcmds
[ address ] ::lnode
Print the specified lnode_t, or a table of the active lnode_t structures in the kernel.
address ::lnode2dev
Print the dev_t (vfs_dev) for the underlying loopback mounted filesystem corresponding to the given lnode_t address.
address ::lnode2rdev
Print the dev_t (li_rdev) for the underlying loopback mounted file system corresponding to the given lnode_t address.
Walkers
lnode
Walk the active lnode_t structures in the kernel. This structure is defined in <sys/fs/lofs_node.h>.
