The controlling terminal can receive signals and send signals. If a foreground process group has the stream as a controlling terminal stream, drivers and modules can use M_SIG messages to send signals to processes.
An overview of Job Control is provided here because it interacts with the STREAMS-based terminal subsystem. You can obtain more information on Job Control from the following manual pages: exit(2), getpgid(2), getpgrp(2), getsid(2), kill(2), setpgid(2), setpgrp(2), setsid(2), sigaction(2), signal(3C), sigsend(2), termios(3C), waitid(2), waitpid(2), and termio(7I).
Job Control breaks a login session into smaller units called jobs. Each job consists of one or more related and cooperating processes. The foreground job, is given complete access to the controlling terminal. The other background jobs are denied read access to the controlling terminal and given conditional write and ioctl(2) access to it. The user can stop the executing job and resume the stopped job either in the foreground or in the background.
Under Job Control, background jobs do not receive events generated by the terminal and are not informed with a hangup indication when the controlling process exits. Background jobs that linger after the login session has been dissolved are prevented from further access to the controlling terminal, and do not interfere with the creation of new login sessions.
The following list defines terms associated with Job Control:
A process group that is a member of a session that established a connection with a controlling terminal and is not the foreground process group.
A session leader that established a connection to a controlling terminal.
A terminal that is associated with a session. Each session can have at most one controlling terminal associated with it, and a controlling terminal can be associated with at most one session. Certain input sequences from the controlling terminal cause signals to be sent to the process groups in the session associated with the controlling terminal.
Each session that establishes a connection with a controlling terminal distinguishes one process group of the session as a foreground process group. The foreground process group has certain privileges that are denied to background process groups when accessing its controlling terminal.
A process group in which the parent of every member in the group is either a member of the group, or is not a member of the process group's session.
Each process in the system is a member of a process group that is identified by a process group ID. Any process that is not a process group leader can create a new process group and become its leader. Any process that is not a process group leader can join an existing process group that shares the same session as the process. A newly created process joins the process group of its creator.
A process whose process ID is the same as its process group ID.
A time period that begins when a process group is created by its process group leader and ends when the last process that is a member in the group leaves the group.
A positive integer that uniquely identifies each process in the system. A process ID cannot be reused by the system until the process lifetime, process group lifetime, and session lifetime end for any process ID, process group ID, and session ID sharing that value.
A period that begins when the process is forked and ends after the process exits, when its termination has been acknowledged by its parent process.
Each process group is a member of a session that is identified by a session ID.
A positive integer that uniquely identifies each session in the system. It is the same as the process ID of its session leader (POSIX).
A process whose session ID is the same as its process and process group ID.
A period that begins when the session is created by its session leader and ends when the lifetime of the last process group that is a member of the session ends.
The following signals manage Job Control: (see also signal(3C)) :
Sent to a process to stop it. This signal cannot be caught or ignored.
Sent to a process to stop it. It is typically used when a user requests to stop the foreground process.
Sent to a background process to stop it when it attempts to read from the controlling terminal.
Sent to a background process to stop it when a user attempts to write to or modify the controlling terminal.
A session can be allocated a controlling terminal. For every allocated controlling terminal, Job Control elevates one process group in the controlling process's session to the status of foreground process group. The remaining process groups in the controlling process's session are background process groups. A controlling terminal gives a user the ability to control execution of jobs within the session. Controlling terminals are critical in Job Control. A user can cause the foreground job to stop by typing a predefined key on the controlling terminal. A user can inhibit access to the controlling terminal by background jobs. Background jobs that attempt to access a terminal that has been so restricted is sent a signal that typically causes the job to stop. (See Accessing the Controlling Terminal.)
Job Control requires support from a line-discipline module on the controlling terminal's stream. The TCSETA, TCSETAW, and TCSETAF commands of termio(7I) allow a process to set the following line discipline values relevant to Job Control:
A user-defined character that, when typed, causes the line discipline module to request that the stream head send a SIGTSTP signal to the foreground process, which by default stops the members of that group. If the value of SUSP is zero, the SIGTSTP signal is not sent, and the SUSP character is disabled.
If TOSTOP is set, background processes are inhibited from writing to their controlling terminal. A line discipline module must record the SUSP suspend character and notify the stream head when the user has typed it, and record the state of the TOSTOP bit and notify the stream head when the user has changed it.
A stream is allocated as a controlling terminal for a session if it:
Is acting as a terminal.
Is not already allocated as a controlling terminal.
Is opened by a session leader that does not have a controlling terminal.
Controlling terminals are allocated with open(2). The device must inform the stream head that it is acting as a terminal.
When a stream head receives a hangup message from a device or module, it is marked as hung up. A stream that is marked as hung up is allowed to be reopened by its session leader if it is allocated as a controlling terminal, and by any process if it is not allocated as a controlling terminal. This way, the hangup error can be cleared without forcing all file descriptors to be closed first.
If the reopen is successful, the hangup condition is cleared.
When the SIGHUP signal is generated by a hangup message instead of a signal message, the signal is sent to the controlling process instead of the foreground process group. The allocation and deallocation of controlling terminals to a session is the responsibility of that process group.
If a process attempts to access its controlling terminal after it has been deallocated, access is denied. If the process is not holding or ignoring SIGHUP, it is sent a SIGHUP signal. Otherwise, the access fails with an EIO error.
Members of background process groups have limited access to their controlling terminals:
If the background process is ignoring or holding the SIGTTIN signal or is a member of an orphaned process group, an attempt to read from the controlling terminal fails with an EIO error. Otherwise, the process is sent a SIGTTIN signal, which by default stops the process.
If the process is attempting to write to the terminal and if the terminal's TOSTOP flag is clear, the process is allowed access.
If the terminal's TOSTOP flag is set and a background process is attempting to write to the terminal, the write succeeds if the process is ignoring or holding SIGTTOU. Otherwise, the process stops except when it is a member of an orphaned process group, in which case it is denied access to the terminal and it is returned an EIO error.
If a background process is attempting to perform a destructive ioctl(2) (one that modifies terminal parameters), the ioctl(2) call succeeds if the process is ignoring or holding SIGTTOU. Otherwise, the process stops except when the process is a member of the orphaned process group. In that case the access to the terminal is denied and an EIO error is returned.
