Please see the copyin section in Writing Device Drivers for information on the 64–bit data structure macros.
Example 8–8 illustrates the processing of a transparent ioctl(2) request only (nontransparent request processing is not shown). In this example, the contents of a user buffer are to be transferred into the kernel as part of an ioctl call of the form
ioctl(fd, SET_ADDR, (caddr_t) &bufadd); |
where bufadd is a struct address whose elements are:
struct address { int ad_len;; /* buffer length in bytes */ caddr_t ad_addr; /* buffer address */ }; |
This requires two pairs of messages (request and response) following receipt of the M_IOCTL message: the first copyin(9F), shown in Example 8–8, copies the structure (address) , and the second copyin(9F), shown in Example 8–9, copies the buffer (address.ad.addr). Two states are maintained and processed in this example: GETSTRUCT is for copying the address structure and GETADDR for copying the ad_addr of the structure.
The transparent part of the SET_ADDR M_IOCTL message processing requires that the address structure be copied from user address space. To accomplish this, the M_IOCTL message processing issues an M_COPYIN request to the stream head.
struct address { /* same members as in user space */ int ad_len; /* length in bytes */ caddr_t ad_addr; /* buffer address */ }; /* state values (overloaded in private field) */ #define GETSTRUCT 0 /* address structure */ #define GETADDR 1 /* byte string from ad_addr */ static void xxioc(queue_t *q, mblk_t *mp); static int xxwput(q, mp) queue_t *q; /* write queue */ mblk_t *mp; { struct iocblk *iocbp; struct copyreq *cqp; switch (mp->b_datap->db_type) { . . . case M_IOCTL: /* Process ioctl commands */ iocbp = (struct iocblk *)mp->b_rptr; switch (iocbp->ioc_cmd) { case SET_ADDR; if (iocbp->ioc_count != TRANSPARENT) { /* do non-transparent processing here * (not shown here) */ } else { /* ioctl command is transparent * Reuse M_IOCTL block for first M_COPYIN * request of address structure */ cqp = (struct copyreq *)mp->b_rptr; /* Get user space structure address from linked * M_DATA block */ cqp->cq_addr = *(caddr_t *) mp->b_cont->b_rptr; cqp->cq_size = sizeof(struct address); /* MUST free linked blks */ freemsg(mp->b_cont); mp->b_cont = NULL; /* identify response */ cqp->cq_private = (mblk_t *)GETSTRUCT; /* Finish describing M_COPYIN message */ cqp->cq_flag = 0; mp->b_datap->db_type = M_COPYIN; mp->b_wptr = mp->b_rptr + sizeof(struct copyreq); qreply(q, mp); break; default: /* M_IOCTL not for us */ /* if module, pass on */ /* if driver, nak ioctl */ break; } /* switch (iocbp->ioc_cmd) */ break; case M_IOCDATA: /* all M_IOCDATA processing done here */ xxioc(q, mp); break; } return (0); }
xxwput() verifies that the SET_ADDR is TRANSPARENT to avoid confusion with an I_STR ioctl(2), which uses a value of ioc_cmd equivalent to the command argument of a transparent ioctl(2).
The if else statement checks whether the size count is equal to TRANSPARENT. If it is equal, the message was not generated from an I_STR ioctl(2) and the else clause of the if else executes.
if (iocbp->ioc_count != TRANSPARENT) { /* do non-transparent processing here (not shown here) */ } else {
The mblk is reused and mapped into a copyreq(9S) structure. The user space address of bufadd is contained in the b_cont of the M_IOCTL mblk. This address and its size are copied into the copyreq(9S) message. The b_cont of the copy request mblk is not needed, so it is freed and then filled with NULL.
cqp = (struct copyreq *)mp->b_rptr; /* Get user space structure address from linked M_DATA block */ cqp->cq_addr = *(caddr_t *) mp->b_cont->b_rptr; cqp->cq_size = sizeof(struct address); /* MUST free linked blks */ freemsg(mp->b_cont); mp->b_cont = NULL;
The layout of the iocblk, copyreq, and copyresp structures is different between 32–bit and 64–bit kernels. Be careful not to overload any data structure in the cp_private or the cq_filler fields because alignment has changed.
xxioc(queue_t *q, mblk_t *mp) /* M_IOCDATA processing */ { struct iocblk *iocbp; struct copyreq *cqp; struct copyresp *csp; struct address *ap; csp = (struct copyresp *)mp->b_rptr; iocbp = (struct iocblk *)mp->b_rptr; /* validate this M_IOCDATA is for this module */ switch (csp->cp_cmd) { case SET_ADDR: if (csp->cp_rval){ /* GETSTRUCT or GETADDR fail */ freemsg(mp); return; } switch ((int)csp->cp_private){ /* determine state */ case GETSTRUCT: /* user structure has arrived */ /* reuse M_IOCDATA block */ mp->b_datap->db_type = M_COPYIN; mp->b_wptr = mp->b_rptr + sizeof (struct copyreq); cqp = (struct copyreq *)mp->b_rptr; /* user structure */ ap = (struct address *)mp->b_cont->b_rptr; /* buffer length */ cqp->cq_size = ap->ad_len; /* user space buffer address */ cqp->cq_addr = ap->ad_addr; freemsg(mp->b_cont); mp->b_cont = NULL; cqp->cq_flag = 0; cqp->cp_private=(mblk_t *)GETADDR; /*nxt st*/ qreply(q, mp); break; case GETADDR: /* user address is here */ /* hypothetical routine */ if (xx_set_addr(mp->b_cont) == FAILURE) { mp->b_datap->db_type = M_IOCNAK; iocbp->ioc_error = EIO; } else { mp->b_datap->db_type=M_IOCACK;/*success*/ /* can have been overwritten */ iocbp->ioc_error = 0; iocbp->ioc_count = 0; iocbp->ioc_rval = 0; } mp->b_wptr=mp->b_rptr + sizeof (struct ioclk); freemsg(mp->b_cont); mp->b_cont = NULL; qreply(q, mp); break; default: /* invalid state: can't happen */ freemsg(mp->b_cont); mp->b_cont = NULL; mp->b_datap->db_type = M_IOCNAK; mp->b_wptr = mp->rptr + sizeof(struct iocblk); /* can have been overwritten */ iocbp->ioc_error = EINVAL; qreply(q, mp); break; } break; /* switch (cp_private) */ default: /* M_IOCDATA not for us */ /* if module, pass message on */ /* if driver, free message */ break;
On receipt of the M_IOCDATA message for the SET_ADDR command, xxioc() checks cp_rval. If an error occurred during the copyin operation, cp_rval is set. The mblk is freed and, if necessary, xxioc() cleans up from previous M_IOCTL requests, freeing memory, resetting state variables, and so on. The stream head returns the appropriate error to the user.
If no error occurred during the copyin operation, the switch statement determines whether to process the user structure, GETSTRUCT, or user address, GETADDR.
switch ((int)csp->cp_private){ /*determine state*/
The cp_private field set to GETSTRUCT indicates that the linked b_cont mblk contains a copy of the user's address structure. The example then copies the actual address specified in address.ad_addr. The program issues another M_COPYIN request to the stream head, but this time cq_private contains GETADDR to indicate that the M_IOCDATA response will contain a copy of address.ad_addr. The stream head copies the information at the requested user address and sends it downstream in another, final M_IOCDATA message.
The final M_IOCDATA message arrives from the stream head. cp_private contains GETADDR. The ad_addr data is contained in the b_cont link of the mblk. If the address is successfully processed by xx_set_addr() (not shown here), the message is acknowledged with an M_IOCACK message. If xx_set_addr() fails, the message is rejected with an M_IOCNAK message]. xx_set_addr() processes the user address from the ioctl(2).
After the final M_IOCDATA message is processed, the module acknowledges the ioctl(2) to let the stream head know that processing is complete. This is done by sending an M_IOCACK message upstream if the request was successfully processed. Always set ioc_error to zero, otherwise an error code could be passed to the user application. Set ioc_rval and ioc_count to zero to reflect that a return value of 0 and no data is to be passed upstream. If the request cannot be processed, either an M_IOCNAK or M_IOCACK can be sent upstream with an appropriate error number. When sending an M_IOCNAK or M_IOCACK, freeing the linked M_DATA block is not mandatory. It is more efficient to use the stream head handle to free the linked M_DATA block.
If ioc_error is set in an M_IOCNAK or M_IOCNACK message, this error code will be returned to the user. If no error code is set in an M_IOCNAK message, EINVAL will be returned to the user.
