STREAMS Programming Guide
High-Priority Messages
High-priority messages are particularly suitable for acknowledging service requests when the acknowledgement should be placed ahead of any other messages at the stream head. High-priority messages are not subject to flow control.
M_COPYIN
The M_COPYIN message is generated by a module or driver and sent upstream to request that the stream head perform a copyin(9F) on behalf of the module or driver. It is valid only after receiving an M_IOCTL message and before an M_IOCACK or M_IOCNAK.
The message format is one M_COPYIN message block containing a copyreq(9S) structure, defined in <sys/stream.h>. Different structures are defined for 64–bit and 32–bit architectures.
#if defined(_LP64)
struct copyreq {
	int      cq_cmd;                /* ioctl command (from ioc_cmd) */
	cred_t   *cq_cr;                /* full credentials (from ioc_cmd) */
	uint     cq_id;                 /* ioctl id (from ioc_id) */
	uint     cq_flag;               /* see below */
	mblk_t   *cq_private;           /* private state information */
	caddr_t  cq_addr;               /* address to copy data to/from */
	size_t   cq_size;               /* number of bytes to copy */
#else
struct copyreq {
	cred_t   *cq_cr;                /* full credentials */
	int      cq_filler[4];          /* reserved for future use */
#endif   /* _LP64 */
The first four members of the structure correspond to those of the iocblk(9S) structure in the M_IOCTL message that allows the same message block to be reused for both structures. The stream head guarantees that the message block allocated for the M_IOCTL message is large enough to contain a copyreq(9S). The cq_addr field contains the user space address from which the data is to be copied. The cq_size field is the number of bytes to copy from user space. The cq_flag field is reserved for future use and should be set to zero.
This message should not be queued by a module or driver unless it intends to process the data for the ioctl(2).
M_COPYOUT
The M_COPYOUT message is generated by a module or driver and sent upstream to request that the stream head perform a copyout(9F) on behalf of the module or driver. It is valid only after receiving an M_IOCTL message and before an M_IOCACK or M_IOCNAK.
The message format is one M_COPYOUT message block followed by one or more M_DATA blocks. The M_COPYOUT message block contains a copyreq(9S) as described in the M_COPYIN message with the following differences: the cq_addr field contains the user space address to which the data is to be copied. The cq_size field is the number of bytes to copy to user space.
Data to be copied to user space is contained in the linked M_DATA blocks.
This message should not be queued by a module or driver unless it processes the data for the ioctl in some way.
Note –
For more information, see copyin and copyout in the Writing Device Drivers manual.
M_ERROR
The M_ERROR message is sent upstream by modules or drivers to report a downstream error condition. When the message reaches the stream head, the stream is marked so that all subsequent system calls issued to the stream, excluding close(2) and poll(2), fail with errno set to the first data byte of the message. POLLERR is set if the stream is being polled. All processes sleeping on a system call to the stream are awakened. An M_FLUSH message with FLUSHRW is sent downstream.
The stream head maintains two error fields, one for the read side and one for the write side. The one-byte format M_ERROR message sets both of these fields to the error specified by the first byte in the message.
There is also a two-byte format of the M_ERROR message. The first byte is the read error and the second byte is the write error. This enables modules to set a different error on the read side and write side. If one of the bytes is set to NOERROR, then the field for the corresponding side of the stream is unchanged. The module can then ignore an error on one side of the stream. For example, if the stream head was not in an error state and a module sent an M_ERROR message upstream with the first byte set to EPROTO and the second byte set to NOERROR, all subsequent read-like system calls (such as read(2)and getmsg(2)) fail with EPROTO, but all write-like system calls (such as write(2) and putmsg(2)) still succeed. If a byte is set to 0, the error state is cleared for the corresponding side of the stream. The values NOERROR and 0 are not valid for the one-byte form of the M_ERROR message.
M_FLUSH
The M_FLUSH message requests all modules and drivers that receive it to flush their message queues (discard all messages in those queues) as indicated in the message. An M_FLUSH can originate at the stream head, or in any module or driver. The first byte of the message contains flags that specify one of the following actions:
Each module passes this message to its neighbor after flushing its appropriate queues until the message reaches one of the ends of the stream.
Drivers are expected to include the following processing for M_FLUSH messages. When an M_FLUSH message is sent downstream through the write queues in a stream, the driver at the stream end discards it if the message action indicates that the read queues in the stream are not to be flushed (only FLUSHW set). If the message indicates that the read queues are to be flushed, the driver shuts off the FLUSHW flag, and sends the message up the stream's read queues.
When a flush message is sent up a stream's read side, the stream head checks to see if the write side of the stream is to be flushed. If only FLUSHR is set, the stream head discards the message. However, if the write side of the stream is to be flushed, the stream head sets the M_FLUSH flag to FLUSHW and sends the message down the stream's write side. All modules that queue messages must identify and process this message type.
If FLUSHBAND is set, the second byte of the message contains the value of the priority band to flush.
M_HANGUP
The M_HANGUP message is sent upstream by a driver to report that it can no longer send data upstream. For example, this might be due to an error, or to a remote line connection being dropped. When the message reaches the stream head, the stream is marked so that all subsequent write(2) and putmsg(2) calls issued to the stream will fail and return an ENXIO error. Those ioctls that cause messages to be sent downstream are also failed. POLLHUP is set if the stream is being polled.
Subsequent read(2) or getmsg(2) calls to the stream will not generate an error. These calls will return any messages (according to their function) that were on, or in transit to, the stream-head read queue before the M_HANGUP message was received. When all such messages have been read, read(2) returns 0 and getmsg(2) will set each of its two length fields to 0.
This message also causes a SIGHUP signal to be sent to the controlling process instead of the foreground process group, as the allocation and deallocation of controlling terminals to a session is the responsibility of the controlling process.
M_IOCACK
The M_IOCACK message signals the positive acknowledgement of a previous M_IOCTL message. The message format is one M_IOCACK block (containing an iocblk(9S) structure, see M_IOCTL) followed by zero or more M_DATA blocks. The iocblk(9S) may contain a value in ioc_rval to be returned to the user process. It may also contain a value in ioc_error to be returned to the user process in errno.
If this message is responding to an I_STR ioctl (see streamio(7I)), it may contain data from the receiving module or driver to be sent to the user process. In this case, message format is one M_IOCACK block followed by one or more M_DATA blocks containing the user data. The stream head returns the data to the user if there is a corresponding outstanding M_IOCTL request. Otherwise, the M_IOCACK message is ignored and all blocks in the message are freed.
Data cannot be returned in an M_IOCACK message responding to a transparent M_IOCTL. The data must have been sent with preceding M_COPYOUT messages. If any M_DATA blocks follow the M_IOCACK block, the stream head ignores and frees them.
The format and use of this message type is described further under M_IOCTL.
M_IOCDATA
The M_IOCDATA message is generated by the stream head and sent downstream as a response to an M_COPYIN or M_COPYOUT message. The message format is one M_IOCDATA message block followed by zero or more M_DATA blocks. The M_IOCDATA message block contains a copyresp(9S), defined in sys/stream.h.
#if     defined(_LP64)
struct copyresp {
	int      cp_cmd;          /* ioctl command (from ioc_cmd) */
	cred_t   *cp_cr;          /* full credentials (from ioc_cmd) */
	uint     cp_id;           /* ioctl id (from ioc_id) */
	uint     cp_flag;         /* see above */
	mblk_t   *cp_private;     /* private state information */
	caddr_t  cp_rval;         /* status of request: 0 -> success */
                           /*   non-zero -> failure */
#else
struct copyresp {
	cred_t   *cp_cr;          /* full credentials */
	caddr_t  cp_rval          /* status of request: 0 -> success */
	size_t   cp_pad1;
	uint     cp_pad2;
	int      cp_filler[3];
#endif  /* _LP64 */
The first three members of the structure correspond to those of the iocblk(9S) in the M_IOCTL message that allows the same message blocks to be reused for all of the related transparent messages (M_COPYIN, M_COPYOUT, M_IOCACK, M_IOCNAK). The cp_rval field contains the result of the request at the stream head. Zero indicates success and non-zero indicates failure. If failure is indicated, the module should not generate an M_IOCNAK message. It must abort all ioctl(2) processing, clean up its data structures, and return.
The cp_private field is copied from the cq_private field in the associated M_COPYIN or M_COPYOUT message. It is included in the M_IOCDATA message so the message can be self-describing. This is intended to simplify ioctl(2) processing by modules and drivers.
If the message is in response to an M_COPYIN message and success is indicated, the M_IOCDATA block is followed by M_DATA blocks containing the data copied in.
If an M_IOCDATA block is reused, any unused fields defined for the resultant message block should be cleared (particularly in an M_IOCACK or M_IOCNAK).
M_IOCNAK
The M_IOCNAK message signals the negative acknowledgement (failure) of a previous M_IOCTL message. Its form is one M_IOCNAK block containing an iocblk(9S). The iocblk(9S) can contain a value in ioc_error to be returned to the user process in errno. Unlike the M_IOCACK, no user data or return value can be sent with this message. If any M_DATA blocks follow the M_IOCNAK block, the stream head ignores and frees them. When the stream head receives an M_IOCNAK, the outstanding ioctl(2) request, if any, fails. The format and use of this message type is described further under M_IOCTL.
M_PCPROTO
The M_IOCPROTO message is the same as the M_PROTO message type, except for the priority and the following additional attributes. When an M_PCPROTO message is placed on a queue, its service procedure is always enabled. The stream head allows only one M_PCPROTO message to be placed in its read queue at a time. If an M_PCPROTO message is already in the queue when another arrives, the second message is discarded and its message blocks freed.
This message is intended to allow data and control information to be sent outside the normal flow control constraints.
getmsg(2) and putmsg(2) refer to messages as high priority messages.
M_PCRSE
The M_PCRSE message is reserved for internal use. Modules that do not recognize this message must pass it on. Drivers that do not recognize it must free it.
M_PCSIG
The M_PCSIG message is the same as the M_SIG message, except for the priority. M_PCSIG is often preferable to M_SIG especially in TTY applications, because M_SIG may be queued while M_PCSIG is more likely to get through quickly. For example, if an M_SIG message is generated when the DEL (delete) key is pressed on the terminal and the user has already typed ahead, the M_SIG message becomes queued and the user does not get the call until too late, becoming impossible to kill or interrupt a process by pressing a delete key.
M_READ
The M_READ message is generated by the stream head and sent downstream for a read(2) if no messages are waiting to be read at the stream head and if read notification has been enabled. Read notification is enabled with the SO_MREADON flag of the M_SETOPTS message and disabled by use of the SO_MREADOFF flag.
The message content is set to the value of the nbyte parameter (the number of bytes to be read) in read(2).
M_READ notifies modules and drivers of the occurrence of a read. It also supports communication between streams that reside in separate processors. The use of the M_READ message is developer dependent. Modules may take specific action and pass on or free the M_READ message. Modules that do not recognize this message must pass it on. All other drivers may or may not take action and then free the message.
This message cannot be generated by a user-level process and should not be generated by a module or driver. It is always discarded if passed to the stream head.
SO_MREADOFF and M_STOP
The SO_MREADOFF and M_STOP messages request devices to start or stop their output. They are used to produce momentary pauses in a device's output, not to turn devices on or off.
The message format is not defined by STREAMS and its use is developer dependent. These messages may be considered special cases of an M_CTL message. These messages cannot be generated by a user-level process and each is always discarded if passed to the stream head.
SO_MREADOFFI and M_STOPI
The SO_MREADOFFI and M_STOPI messages are the same as SO_MREADOFF and M_STOP except that SO_MREADOFFI and M_STOPI are used to start and stop input.
M_UNHANGUP
The M_UNHANGUP message reconnects the carrier after it has been dropped.
